Only the head lights work, nowt working at the rear, also no dash lights.
Just back from having a quick look, (in the dark) and I have found:-
Under bonnet-
No. 8 fuse ok. ( 12v present at both test points)
No. 9 fuse was blown, and has been replaced by us.
No. 10 fuse is missing.
No. 7 fuse is missing.
No.12 relay, which is under the same cover is missing, but it does look like it's never been there. ( there is 12V at the connection)
H270 relay is hidding somewhere? It's not in the same place as mine (on inner wing, passengers side, and to the front) I believe this is the relay for the rear lights.
Last but not least, the rear fog is a red lamp in the drivers side reversing lamp holder.
Oh and as soon as the ignition is switched, the rad fans come to life. (have since seen on here, it could be because the air con is switched on?)
I am hoping to get another quick look tomorrow morn, unless my new radiator arrives.
Cheers.
