we have a loud creeking noise from the rear passenger side when we turn left. Strangely it disappears when its wet.
Any ideas what it could be?
boyzie
Rear creek when turning left
- daveblueozzie
Re: Rear creek when turning left
with any luck just a noisy spring, try a bit of WD40 where the spring joins at the top and bottom.
Lost without my Bongo.
Could also be a 'dry' rubber bush in the shock absorber. When its wet the water acts as lubricant so it goes away. Again a squirt of WD40 (being careful not to get any on the brakes) should do the trick.
1995 N reg 2WD AFT in green/grey
www.whiteroseancestry.co.uk
