roof problems.
aid175
roof problems.
Post by aid175 » Mon May 05, 2008 11:37 am
i am having problems lifting my roof.i haven't used the roof space for around 5 months and now it won't lift at all..could it be the fuse? if so which fuse is the roof one? thanks
Re: roof problems.
Post by Ian » Mon May 05, 2008 11:49 am
Before investigating further, have you checked the obvious? The handbrake must be on before the roof will go up.
mister munkey
Re: roof problems.
Post by mister munkey » Mon May 05, 2008 11:50 am
I sometimes suffer this. Mine seems to have a bit of an erratic switch under the handbrake. Dropping it & yanking it up again eventually makes it work.
aid175
Re: roof problems.
Post by aid175 » Mon May 05, 2008 11:52 am
yeah i've tried handbrake stuff and without the engine running to hear if the motors are running!
Re: roof problems.
Post by Ian » Mon May 05, 2008 11:54 am
30 amp fuse, second row down, fourth from left. But I'm with Mistermunkey, I reckon it will be the switch at rear of handbrake.
aid175
Re: roof problems.
Post by aid175 » Mon May 05, 2008 11:56 am
ok guys thanks,i'll go out and give things another go and post how i get on in a mo.cheers
Ralph
Re: roof problems.
Post by Ralph » Mon May 05, 2008 12:33 pm
if it's the hand brake the light on the dash wont come on
