That is intresting, as the Bongo cooling system can't cool the engine from the radiator when the engine is off.Grahame at work wrote:Hi All
Aethelric - the fan is controlled through the ECU and this has direct feed as well as feed via the ignition switch and so can hold the fan relay on for as long as the temperature is high and is timed off after the temperature falls even after the ignition is switched off. The feed for the fan is also direct rather than through the ignition switch.
Regards Grahame
Fitted Scavenger Fan over-ride switch :-)
- The Great Pretender
Re: Fitted Scavenger Fan over-ride switch :-)
To infinity and beyond
- Peg leg Pete
Out today in this glorious weather, as I turned off ignition, heard the scavenger fan run and slow down to a stop, I had cleaned the terminals this morning as the handbrake was hot yesterday after a long uphill run.
Pete- mikeonb4c
Well now that IS interesting Pete, as it opens up the possibility I was hinting at the other day on another thread i.e. who's to say that the fan hasn't stopped working on some old Bongos because the sensor has gone AWOL. We know this kind of thing happens with other sensors. But if it happens with the scavenger fan, it may be of no consequent until a 'hot engine day' arrives and it was needed. It may be on an occasions like that when the mysterious reports of Bongos pulling in after a hard run then pushing coolant out of the header tank happens. This is all uninformed speculation of course, but it does make you think.Peg leg Pete wrote:Out today in this glorious weather, as I turned off ignition, heard the scavenger fan run and slow down to a stop, I had cleaned the terminals this morning as the handbrake was hot yesterday after a long uphill run.
I did a small test today, running the scavenger fan using the over-ride switch. Unless I'm very much mistaken, the handbrake base, and the side of the engine compartment seemed noticeably cooler at the end of the run than they had been after a similar run earlier in the day. I'll post with an update as and when I get more conclusive evidence.
