Faulty Mazda Ga5r Speedo
Jolly Rogers
I have got hold of a Mazda Ga5r speedo. The only problem is its faulty. The fault is when you start the engine the speedo needle goes straight to 20mph, even though the engine is just idling
Any idea if this is something I can fix?
Re: Faulty Mazda Ga5r Speedo
pull off the need (carefully) using a small screw driver or t spoon handle, turn on the ignition and push the needle back on and it will be set at 0 again
Jolly Rogers
Thanks wil give that a go
I have pur the old speedo back in ](./images/smilies/eusa_wall.gif)
forgot to say, when you put the needle on, make sure the end of it is pionting down to the 0, where the thin stop needle is
- maxheadroom
Jolly Rogers, did you have a chip fitted? and have you re-fitted it? as you are not supposed to. Just a thought.
Maybe the face has been removed to re-set the odometer (which it doesn't need to be) and maybe the needle hasn't been re-fitted properly.
Sorry not much help but I'm sure nothing to worry about
Jolly Rogers
Thanks for the advice.
Its not been chipped, I think it will be just matter of doing what waycar8 said to do
