Removing fuel pump
parawaiting
Removing fuel pump
after my previous post about leaking diesel and replacing all the seals i could with the pump in place, i've found the leak still exists so i need to tke the pump out so i can replace all the other seals i couldnt access.Has anyone stripped the fuel pump before? is it as simple as it sounds or are there any pitfalls? cheers paul
parawaiting
Re: Removing fuel pump
come on someone must have done it
- westonwarrior
I have not heard of anyone doing this, so if you do, please take notes and pictures it may help the next person to try.
