A question for all Tin toppers?
My sun roof works fine, i keep the runners lubed & the guttering clear..
I don't really use it that often, but i have noticed it doesnt have an auto stop function like the windows/mirrors/blinds.
It does however on closing stop exactly half way, then when the rocker switch is let go & pressed again the sunroof caries on till closed.
It's just at the end of travel, either opening or closing there don't appear to be the motor saving function as mentioned referring to the other motorised utilities...?
Is this normal design or something i need to investigate?
Cheers!
Cheers!
				Mr Halibut
Re: A question for all Tin toppers?
I don't have a sunroof
Mine does the same, it appears to be something to do with the blind/shutter thing underneath and how that closes, but I could be wrong.jaylee wrote:My sun roof works fine, i keep the runners lubed & the guttering clear..
Cheers!
Not sure exactly what you mean here
Mine opens as long as a keep switch pressed.,nd stops when i release the button. It will stop in
any position.
Works the same when closing. stops and restarts as and when i push the button.
Brian
any position.
Brian
What happens with Jaylee's and mine is this.
If it is open and you press the button to close it and hold it there it stops halfway, whether or not you release the button.
To complete the closure you have to release the button and press it again.
Obviously if you release the button at any other point when opening or closing it it stops at that point.
It doesn't automatically stop halfway when being opened, only when being closed.
				Mr Halibut
does it keep posting if you leave your finger on the buttona s well?Bongoplod wrote:Not sure exactly what you mean here
any position.
Brian
Yep, Scanner just summed it up Brian.
my question is, when the sun roof is fully open or closed even with the switch pressed does the winder motor still keep going or does it auto stop like the windows/blinds?
Now the sun roof is out of the line of sight, i tend to know when its fully open/closed because i can hear a change in the motor tone & i let go of the switch!
With the blinds for instance, if you hold the down button the appropriate blind will stop when fully traveled you will not hear the motor the unit that has traveled as far as it will go...
That don't seem the case with my sun roof though it works fine in every other respect.
...I'm just after a comparison with other tintop sun roofs, if it ain't broke i'm not gonna try to fix it!
Mr Halibut wrote:does it keep posting if you leave your finger on the buttona s well?Bongoplod wrote:Not sure exactly what you mean here
any position.
Brian
I was gonna do a Hello Hello Hello joke, but two of Brian's statements appear to have been retracted!!
When mine fully closes or opens the note of the motor changes as the clutch starts to slip.
You can hear the motor running and the clutch slipping.
It's a sort of "be-dump" "be-dump" "be-dump" noise.
- Muzorewa
For a moment there I thought I was reading the 'lost portaloo' threadscanner wrote:It's a sort of "be-dump" "be-dump" "be-dump" noise.
Oi I am watching youMuzorewa wrote:For a moment there I thought I was reading the 'lost portaloo' threadscanner wrote:It's a sort of "be-dump" "be-dump" "be-dump" noise.
Love to help but i not got a sunroof
 would be nice tho i suppose
 is that why i got climate control
									All disclaimers count  as i know nothing
Not necessarily as I've got both.cheffy34 wrote:Love to help but i not got a sunroofwould be nice tho i suppose
				BennyBongo
As I understand it the reason the sunroof only closes halfway at the first press of the switch is a safety issue so that people (kids) don't get decapitated accidentally if they have their heads up through the sunroof.
When it's fully open there's a click as it latches the under panel shutter thing, ready to drag it closed when shutting..scanner wrote:When mine fully closes or opens the note of the motor changes as the clutch starts to slip.
Its great for star gazing at night!
