We've got a SS exhaust from MIJ Performance in Walsall after a number of recommendations on here; our standard one is looking totally knackered and we're away to Italy on the 21st.
So I need to get it fitted this weekend and I was wondering if anyone else has done this themselves (the places around here are either too busy or too snotty to fit it)?
We've got the standard 2-part turbo-back single tailpipe jobbie the same as brora's.
I gather I've got to retain the "O ring" (gasket?) from the turbo/downpipe join and disconnect and bypass the cold start flap thing but I'm wondering if I need a gasket for the other join (the one between the two sections of pipe) and if so whether a suitable one will fall off from somewhere when I remove the existing OEM exhaust or if I should use instant gasket? Is it easy enough to dismount and remount from the rubbers and hangers?
I gave all the bolts a dose of WD40 a couple of days ago and will give them another one tonight so I'm hoping when I come to do the deed tomorrow it should all be straightforward but thought I'd check for any tips just in case as this is about the upper end of my DIY spannering.
Cheers,
Paul
