pulling away
searchers
pulling away
hi all
maybee nothing but when i start to pull away in the bongo first thing when she is cold it does not seem to want to i start off on a hill and she wont pull away as normal just creeps along no revs but if i apply the handbrake and rev seems to build up and will pull away ok it revs freely when its out of gear and no problem when warm
thank you for reading any help would be nice
mike
mike
Re: pulling away
Do you have twin batteries fitted searchers? Not a leisure battery, the cold climate set up.
Veg_Ian
Re: pulling away
A couple of questions:
1. You aren't referring to the 3rd to 4th gear lockup that only works when warm?
2. Are you running with a high percentage of veg oil?
- missfixit70
Re: pulling away
may be worth checking the banjo filter as per the factsheet in the members area & maybe check the drain on the fuel filter & possibly change it if it hasn't been done in the last year. Is there any smoke or any other symptoms?
searchers
Re: pulling away Amended
Thank you all for your quick replies
No Veg oil
not long had air = Fuel filter changed
Its pulling away from stop first thing in the morning
Ta Mike
No Veg oil
Ta Mike
- missfixit70
Re: pulling away
You've had the oil filter changed but have you checked or changed the fuel filter? or the banjo filter on top of it?searchers wrote:Thank you all for your quick replies
No Veg oil
not long had air = iol filter changed
Ta Mike
searchers
Re: pulling away
hi
have amended my last post
i meant to put fuel filter has been changed
the banjo when i took it off did not see a filter in so just put it back together
thanks for reading and replies
Re: pulling away
Ahem....Have you a twin battery set-up ?
searchers
Re: pulling away
hi
leisure battery fitted as per the diagrams on the techie pages
no winter pack as far as i know
Re: pulling away
Thanks searchers, i was thinking that perhaps the flap in the exhaust could be faulty, and sticking slightly (when left overnight), then a bump in the road could have opened the flap again...
You don't have the cold climate twin battery set-up, so no flap in the exhaust.
Re: pulling away
Hmm, on second thoughts....
Have you got a switch next to the "rear" switch, with a picture of an engine on it?
It's just possible you HAD the cold climate set-up originally? And the second battery has been removed,the wiring removed, but the original exhaust left in place?
I know it's a long shot....
searchers
Re: pulling away
thanks
with the battery setup i had to make my battery tray as none had been fitted before, (paint on tread holes)
it seem to build up pressure and then its ok only about 10 to 15 seconds
if i dont pull on the handbrake or footbrake it just seems like clutch slip but the revs dont build once its moving its ok
searchers
searchers
