Where is my output speed sensor?
WISHIHADABONGO
Anyone know?
Si
Si
nfn
Re: Where is my output speed sensor?
Hopefully someone with more experience will answer, but my guess is that the output speed sensor is in the speedometer. Is your speedometer working?
WISHIHADABONGO
Yep my speedo works prefectly, I still would like to know where it is and how to repalce it.nfn wrote:Hopefully someone with more experience will answer, but my guess is that the output speed sensor is in the speedometer. Is your speedometer working?
- maxheadroom
I think it's right at the back of the gear box on top but don't quote me, just have a look from under the car. A 10mm bolt holds it in.
WISHIHADABONGO
From looking on google I think you are right.maxheadroom wrote:I think it's right at the back of the gear box on top but don't quote me, just have a look from under the car. A 10mm bolt holds it in.
Anyone know where I can purchase one?
- maxheadroom
WISHIHADABONGO
More Googling then....maxheadroom wrote:it's a Nissan gear box so you could start there
- maxheadroom
- brorabongo
WISHIHADABONGO
Code I had was 60.... output speed sensor not at fault, you were correct where it is tho...for future rference I have a spare....
