Odometer stuck
- Peg leg Pete
Odometer stuck
Our Bongo clocked up 89999 miles and now refuses to move any further, tripometer has ceased to move also, Speedometer is working fine, any suggestions please as to how to rectify the problem
 Pete
       Pete- westonwarrior
Re: Odometer stuck
Have you tried resetting the trip?
have you tried taking it out and knocking the dials on a notch?
- Peg leg Pete
Re: Odometer stuck
Tried resetting trip, did not alter anything, will have to have a look tomorrow , thanks for your swift response Rob
 Pete
       Pete- You've Been Bongod
Re: Odometer stuck
hi pete it isnt your chip playing up is it ?
you've been bongod
									you've been bongod
						Re: Odometer stuck
Mine was a bit sticky after I took out the speedo to conect the cruise, I'm with Rob that taking it out and gently jiggling it could free the dials.
						Re: Odometer stuck
Mine stuck as it turned 99999 miles. Resetting the trip didn't work, but a good hard tap on the plastic screen while driving did the trick. Otherwise I would try removing the dash & manually turning it with a small screwdriver.
						Re: Odometer stuck
Just give the last wheel a prod with a match stick.(the blunt end)
Mal..
						Mal..
- Peg leg Pete
Re: Odometer stuck
Cheers for advice, not a chipped speedo, Have not had a chance to remove speedo today, will hopefully get to have a look on Sunday
 Pete
       PeteRe: Odometer stuck
Let us know if you get this one sorted. My trip meter sticks but so far the totals are ok. My trip gets stuck under a mile or goes ok so I always know if its working or not.
						- Peg leg Pete
Re: Odometer stuck
Well never did get chance to remove speedo to sort out the stuck guage  Set off at 3.30 a.m. yesterday to take Matthew to work, drove over curb to avoid reversing up the street, as we were travelling along noticed that the tripometer and odemeter had decided to start working again
 Pete
       Pete
