floppy wipers
meek.tv
floppy wipers
Post by meek.tv » Tue Sep 09, 2008 12:58 pm
my wipers are flopping too low past he windscreen rubber surround and make an really annoying clunk as well as having a great added effect of occasionally pinging a wiper blade off the arm everyonce and a while.
i thought that the solution would be to remove them and refit them slightly higher so they dont go down so far but im worried that ill get the opposite effect of the driverside wiper going too far to the right.
at the height of its sweep the drivers side blade just about touches the windscreen rubber so im worried itll go too far if i change.
ive also noticed that at motorway speeds i dont have the problem as the wind resistence seems to keep them off the bottom.
will removing them and refitting sort the problem or is it just a knackered motor giving it too much flop?
.......... cycling more.
Veg_Ian
Re: floppy wipers
Post by Veg_Ian » Tue Sep 09, 2008 12:59 pm
What you propose is the usual fix for this. Just one notch on the splined shaft should do it
meek.tv
Re: floppy wipers
Post by meek.tv » Tue Sep 09, 2008 1:06 pm
so no worries about it going too far the otherway?
looks like a fight with a pair of wiper baldes int he rain for me when i get home :)
Re: floppy wipers
Post by mikeonb4c » Tue Sep 09, 2008 1:09 pm
I guess you can only 'suck it and see'. Hope they come off the splines OK. Thing is, why are they doing it. Is there play in the system and if so, is something either in need of adjustment/tightening up or is it on the way out? You might want to investigate? :roll:
meek.tv
Re: floppy wipers
Post by meek.tv » Tue Sep 09, 2008 1:28 pm
mikeonb4c wrote:Thing is, why are they doing it. Is there play in the system and if so, is something either in need of adjustment/tightening up or is it on the way out? You might want to investigate? :roll:
thats what im worried about....although i wouldnt know where to start to look for the problem :S
Re: floppy wipers
Post by missfixit70 » Tue Sep 09, 2008 1:40 pm
The mechanism is all nicely visible once you lift the bonnet, I'm sure you'll see if there's anything amiss, hopefully moving it round a spline should be ok though.
tricky
Re: floppy wipers
Post by tricky » Tue Sep 09, 2008 2:24 pm
meek.tv wrote: at the height of its sweep the drivers side blade just about touches the windscreen rubber so im worried itll go too far if i change.
You really want to avoid them contacting the windscreen rubber at either end of the stroke as they will wear notches in the screen rubber and can cause leaks etc. This was a problem seen on the MG RV8 where the wee 11" blades had very little room for comfort on the screen.
bongomaan
Re: floppy wipers
Post by bongomaan » Tue Sep 09, 2008 7:14 pm
I got some of these "Mazda Bongo RETRO FIT Flat AERO Wiper Blades (#280241189863) " excellent ( ebay !)
Re: floppy wipers
Post by bigdaddycain » Tue Sep 09, 2008 7:25 pm
Mine are lined up level against the black strip on the bottom of the screen, the sweep seems right set up that way,i removed mine to re-spray the wiper arms last year, only then did i notice they weren't as level as they could be.
Re: floppy wipers
Post by francophile1947 » Tue Sep 09, 2008 7:55 pm
Are you sure that you haven't just got longer blades than they should be?
M 80NGD
Re: floppy wipers
Post by M 80NGD » Tue Sep 09, 2008 8:39 pm
bigdaddycain wrote:Mine are lined up level against the black strip on the bottom of the screen, the sweep seems right set up that way,i removed mine to re-spray the wiper arms last year, only then did i notice they weren't as level as they could be.
Checked mine today,just out of interest,and they're exactly as BDC's are :DThat'll do Me :wink:
My Names Bond......Lee Bond!!
Re: floppy wipers
Post by bigdaddycain » Tue Sep 09, 2008 8:44 pm
Yip, i can tell that from your avatar M80...job's a good un' :wink:
Good point about the wrong sized blades john.... :wink:
meek.tv
Re: floppy wipers
Post by meek.tv » Wed Sep 10, 2008 12:16 am
thanks for the info.
way too wet to go playing bongo outside tongiht so ill have a look in the morning
fi i remember correctly i can move te arms up and down a fair bit by hand......is this nromal or does it indicate someting somewhere is more worn than it should be?
give me about 12 hours and i will be reposting here with a "ooops ive broken something" post no doubt
meek.tv
Re: floppy wipers
Post by meek.tv » Wed Sep 10, 2008 8:34 am
ok there is a fair bit of play. heres a couple of pics of how much i can move the wipers when parked up
is this a lot more than usual?
what do i do to remedy??
Re: floppy wipers
Post by Bob » Wed Sep 10, 2008 8:46 am
That does seem like alot of play to me, could be the mechanism needs replacing.
