Bleeding a V6
Regor
Bleeding a V6
Post by Regor » Thu Sep 11, 2008 8:39 pm
Here's a quick question to all the coolant system fundis out there. Does a V6 system require bleeding after being disturbed like the diesels, and if so how is it carried out.
Thanks in anticipation
Regards
Roger
Re: Bleeding a V6
Post by francophile1947 » Thu Sep 11, 2008 8:43 pm
All cooling systems need bleeding - it's just that most are easy to do :lol:
No idea about the V6 I'm afraid :(
cheffy34
Re: Bleeding a V6
Post by cheffy34 » Thu Sep 11, 2008 9:25 pm
I have been told that its the same princaple, not done mine as off but want to flush it before winter just because i like playing :D as per factsheet it has been said but maybe someone wants to prove me wrong :D
Re: Bleeding a V6
Post by Bob » Thu Sep 11, 2008 11:29 pm
Have a look under the n/s seat and see if there is a bleed tube. Passes over the altenator and secured to the chassis with a cable tie thingy.
The Great Pretender
Re: Bleeding a V6
Post by The Great Pretender » Fri Sep 12, 2008 12:30 am
Regor wrote:Here's a quick question to all the coolant system fundis out there. Does a V6 system require bleeding after being disturbed like the diesels, and if so how is it carried out.
Regards
Roger
Quick answer, yes and from the highest point. :wink:
To infinity and beyond
apole
Re: Bleeding a V6
Post by apole » Fri Sep 12, 2008 3:27 pm
I've watched mine being done and the answer is yes, there is a bleed pipe under the passenger seat. Should imagine it's very similar to the diesel engine procedure.
Andy
