I have a switch located under the steering Colum on the removable panel.
For the first time I had my lights on dipped beam, when I parked at the gates to my work the lights went onto sidelights then when moving off came back onto dipped beam, the switch turns this function on and off.
Must be a battery saving thing.
Switch????
ns400r
Re: Switch????
Japan has appalling traffic congestion and you know how annoying it is to have bright lights burning the hair off the back of your neck when the guy behind keeps his lights on in a queue?ns400r wrote:I have a switch located under the steering Colum on the removable panel.
That stops you annoying people driving those tiny little Jap minicars whose rear window is exactly the same height as Bongo headlights.
