Running UK appliances from Japenese Electrical Sockets
Geggsie
I have just bought a Bongo which the electrical sockets and hook up are Japenese and run at a different voltage (100v I think). I know I can buy an adapter plug but am concerned about the voltage difference. Ultimately I have updating the conversion so will get it all permanently changed then but in the interim any advice would be greatly appreciated
Re: Running UK appliances from Japenese Electrical Sockets
Welcome to the madhouse
- don't forget to put your location in your profile, as it really helps us to help you.
You can get adaptors, but you'd also need a transformer to put the voltage up to 230v. Probably better to rewire the whole thing to UK specification.
francophile1947 wrote:Welcome to the madhouse- don't forget to put your location in your profile, as it really helps us to help you.
Hi John,do you not mean down to 110v.
Regs Mal..
Oopsteenmal wrote:francophile1947 wrote:Welcome to the madhouse- don't forget to put your location in your profile, as it really helps us to help you.
Regs Mal..
Hi Geggsie,
Rewiring wont solve any thing,you will have to use a step down transformer from 240v ac to 110v,if the appliances are 110v.
Regards Mal..
Regards Mal..
I take your point, but he was referring to the sockets, wasn't he?
- crazy uncle gray g
to put in your awning and run what you like from it including a 110 transformer to run power into your van. I`ve done just that for nearly 4 years no problem
cheers! party on dudes.
