Front drop links
manners
Front drop links
Hi, how do you change the front drop link? do you have to jack up support anything or just unbolt and replace?
cheers manners.
cheers manners.
Re: Front drop links
manners
Thanks for that, did a search but that post didn't pop up
I knew I had read somewhere about jacking up and supporting the axles.
No problems
- sometimes the search comes up lucky
Good luck with the repair.
Hi there
I was going to do the tight nuts joke, but I won't bother now
F Zappa
F Zappa
manners
Well changed the drop links OK, but have still got a slight knocking noise? only when going slow ( up to 15 MPH) defiantly coming from the front and is about 3 to 4 quick muffled knocks a bit like Rolf Harris on his wobbly board instrument thingy anybody any ideas?
- crazy uncle gray g
manners wrote:Well changed the drop links OK, but have still got a slight knocking noise? only when going slow ( up to 15 MPH) defiantly coming from the front and is about 3 to 4 quick muffled knocks a bit like Rolf Harris on his wobbly board instrument thingy anybody any ideas?
http://www.youtube.com/watch?v=9M_Zh_Azz-4
cheers! party on dudes.
Ditto when I did mine. It was the anti-roll bar bushes. Rather than buy new, I sleeved them with some bicycle inner tube rubber and clamped them up and everything was hunky dory. V quick and easy to do. Do a neat job and I can't see an MOT station noticing, let alone caringmanners wrote:Well changed the drop links OK, but have still got a slight knocking noise? only when going slow ( up to 15 MPH) defiantly coming from the front and is about 3 to 4 quick muffled knocks a bit like Rolf Harris on his wobbly board instrument thingy anybody any ideas?
PS - did a thread on it somewhere, with pics, which I've put below for convenience (click thubnails):
Lloydy
Had the same problem myself.
The anti-roll bar bushes are a good bet for this one. You can either fix them as above or buy new ones for about £10 a pair.
I have previously wrote a detailed topic on this job. You have to be careful when undoing the bolts that hold the bush brackets as they can shear easily. Not a huge problem apart from the fact that the bolts are captive and have a fine thread (you cant replace the nuts with normal ones).
Its a REALLY easy job though. Just take your time and make sure you have spares to hand.
If it isnt these bushes then check the rear wishbone bushes. I have seen these gone before. Bit more of a job and more expensive so fingers corssed mate!!
Good luck,
Lloydy
Good luck,
Lloydy
manners
Thanks for the pointers
Are these rear wishbone bushes as it seems a bit off centre to me
If so does anybody know how to change them or even get them from
manners
Found the bushes anybody know how to fit them?
