How do you bleed the power steering
westonwarrior
Steering Rack Seals Removal?
Post by westonwarrior » Tue Oct 14, 2008 8:12 pm
I have a member who is trying to replace the seals on his steering rack and has hit a problem
Steering rack is removed and 2 of the seals are off but the other 2 won't budge
Any one replaced their seals and can give a blow by blow discription please.
Their location is St Austell
His bongo has been on axel stands for too long and needs a good work out :lol:
Re: Steering Rack Seals Removal?
Post by missfixit70 » Tue Oct 14, 2008 10:17 pm
Can't help but will be interested to hear the answer as I've got one waiting to be done [-o<
Post by Bob » Tue Oct 14, 2008 10:59 pm
Since the rack has been removed it might be worth taking it up to Allan's, Plymouth.
chrisd2211
Post by chrisd2211 » Sat Oct 18, 2008 7:00 pm
OK it is done, we had drill two little holes in top of inside seal and screw in small sefl tappers to pull one seal out the other internal seal involved taking the whole rack to bits to get it out bit of a tricky one but achievable.
chrisd2211
Post by chrisd2211 » Sat Oct 18, 2008 7:05 pm
Hi guys
Once again I have returned with a small problem the steering has been reconed and now when i start engine my new supa dupa boots inflate with what i can only hope is air so how do you bleed the system or is possible i still have a problem i believe that it may be possible for air to pass thru the sealed system but not oil??is this correct or indeed do the boots fill with oil ??? please help I am this close to gettin my baby back!!!
Chrisd2211
Re: How do you bleed the power steering
Post by missfixit70 » Sat Oct 18, 2008 7:10 pm
Sounds to me like you still have a problem :( , the boots shouldn't be part of the system as such, they are just there to keep the crap out.
Post by francophile1947 » Sat Oct 18, 2008 7:18 pm
Is the power steering fluid level going down? As Kirsty says, the boots are only to keep dirt out. I hope you haven't fitted the seals the wrong way round (if that's at all possible :? )
chrisd2211
Post by chrisd2211 » Sun Oct 19, 2008 10:36 am
regretably No!! bongo not back on road..................it is still leaking oil into boots and i have had to remove it again does anyone know what else can go wrong with it I have resealed it (Correctly) and have replaced the boots what more is there to do!! is it worth getting the actual pump looked at?? That said the boots inflated like balloons when i started her up yesterday i am at my wits end !!! (I caught a post about a co. in PLymouth called allans ?? anyone have a contact please
Chrisd2111
Post by bigdaddycain » Sun Oct 19, 2008 10:38 am
Most power steering systems are self bleeding, i.e. you simply lock the wheel over from left to right a few times to pressure up and force out unwanted air.
westonwarrior
Post by westonwarrior » Sun Oct 19, 2008 11:49 am
http://www.allansvehicleservices.co.uk/
You could also pm Doone
They have a good Rep and I am hoping to vist them soon myself
chrisd2211
Post by chrisd2211 » Sun Oct 19, 2008 3:18 pm
Only MEEEE!!! does anyone know is there is a pressure relief valve located anywhere ie pump or rack this may be the cause of my problems??
Thanks in advance Chrisd2211
Post by Doone » Mon Oct 20, 2008 9:12 pm
Allan has replied to the pm you sent.
