How many idiots does it take to change a light bulb?
trevorjtaylor
- Junior Bongonaut
The answer is more than 1...
How do I get at the rear lights on my Ford Freda? Tried undoing a couple of bolts at the side but there seems to e something else holding it.
dp bradford
Re: How many idiots does it take to change a light bulb?
Remove the two obvious screws then push the unit sideways. You might need to give it a gentle thump to get it to move.
Dave
Dave
trevorjtaylor
- Junior Bongonaut
Dave
When I tried that it looks like the whole rear unit moves. Its a mew-style Freda, S reg. You reckon just give it a good shove?
dp bradford
I don't know if the new Freda is different - mines an older one. On mine the whole unit comes out as one.
Dave
Dave
Shads
The bongomaster has a youtube video on how to take a rear light cluster off, it's top viewing.
Shad
Shad
- missfixit70
But don't follow it
you'll break your lights - it slides out sideways after undoing the 2 screws, don't try & lever it out as in the video
I'm not sure the video exists any more..?
I can't find it on the Tube, just the roof raising one.
I just undid 2 screws & gave it a solid shove..
- missfixit70
You could be right Jaylee, I can't not find it niether
New or old, same principle applies, same mounting points,and anchorage clips.
Some are a bit sticky, and need some GENTLE persuasion!
Tap the light unit from the inside, outwards...then towards you.
If it's any consolation,no way are they as tricky to remove as the plastic covers for the mirror base!
