As I've said, I don't have a Bongo so I don't know ... but disconnecting the battery seems a bit over-the top to me. Would you do that to change a side-light bulb? ... and surely it's inadvisable as well as un-necessary to disconnect the +ve terminal as well as the earth.dvisor wrote:Thanks.teenmal wrote:Hi Dvisor,
Well done good info,does the wiring instructions tell you to disconnect the battery first?
Only a thought.![]()
Cheers Mal..
Didn't think about disconnecting the battery firstGuess I should've done really, to be on the safe side.
Generally, if turning everything off means there is nothing live in the area that you are working, for any job, then that should be sufficient, so long as no-one is going to come along and turn it on - but as I say I don't know if that is the case for working behind the instrument panel in a Bongo.
Disconnecting the battery is usually only necessary when working around areas like the starter motor, the fusebox or the ignition switch. Even then it is only necessary to disconnect the earth terminal which then totally prevents any power from coming out of the battery.
It's never easy to choose between "being on the safe side" and taking shortcuts to keep things simple and save time and money. I hope someone here is brave enough to be definite about whether the chore of disconnecting/reconnecting the battery must spoil the pleasurable simplicity of fitting a Mason alarm. If it is really advisable then let's add what size spanner is needed to the instructions and remove the dubious advice to touch the +ve terminal.
