Small lever under bonnet.
Re: Small lever under bonnet.
both my bongos ive owned have been from the north of japland, and both had climate control and both had that lever, but wasnt controlled by the unit in the cab
but my first 95 n had the same intake as the picture but my new 97 r has the same but with an extra vent running across the top so it can draw air in from the top of the vent intake cover as well as the front of the intake cover
- haydn callow
Part 61-805 on that diagram is the flap that was moving by moving a slider. It either was flush with the floor of the trunking in position 1..or...Position 2..it flapped upwards into the trunking (hinge at back) so it deflected air that would have gone along the trunking out and down.
I think !!
I think !!
- haydn callow
Hang on ! more tosh !!!
In that diagram (lushprojects) the flap is hinged from the top of the trunking....The one I saw defo hinged up from the bottom !!
- dandywarhol
I'm sure 61-B05 is worked by a control in the cabin - the winter/summer manual flap shuts off the incoming cold air from the extreme front of the engine bay and draws it from the warmer direction at the baulkhead
not sure what you mean? are you talking about the intake (61-820) or the cowling that the fan motor is in? (61-B05)
- maxheadroom
- haydn callow
Have had a good look at lush projects...Is there not two totally different versions of the whole intake cowling ??
Yep...just pull it.
Yep...just pull it.
- haydn callow
I'm off to annoy another Topic...Dandy...was your NW remark a innocent oversight ?? You'll get a telling off !
haydn callow wrote:Have had a good look at lush projects...Is there not two totally different versions of the whole intake cowling
Ive said that already
- dandywarhol
haydn callow wrote:I'm off to annoy another Topic...Dandy...was your NW remark a innocent oversight ?? You'll get a telling off !
- mister munkey
My winter pack has the lever. Its in the manual as being an adjuster for cold weather motoring but the diagram is somewhat ambiguous as to which way it should be flicked for cold.
manners
Back for cold forward for normal climate.
emma & ian
I'll move it to the back and see if it makes any difference, thanks for your help.
thedogsbollox
- Tribal Elder
If you take the advice of just pulling it, please retire to a safe distance....
