heater not blowing to leg
Hi any suggestions on why my heater will only blow air out of dash vents, it wont blow to leg/feet or windscreen?
That'll Be The Day.........
'99 Silver V6 Moonfleet Conversion
- missfixit70
Re: heater not blowing to leg
Loads of threads on this, seems to be a common problem, check the linkages in the drivers footwell, may be broken or just need clipping back in. Did it ever work? Recently had one that the actuator motor was missing. Have you got slider controls or digital climate control?
only got her a week ago dont know if it was working on the road up from poole, but its not worked since getting her home, it is the digital one, thanks for the reply will have a look
Hi had a look and i can turn it onto my legs then onto my dash but using the switch it doesnt work,
at least i can have hot legs now
- missfixit70
In the picture above the actuator motor is missing ( posted the wrong piccy
), top right where the connector is with nothing connected to it.
Here is what it should look like
Check you've got the actuator installed & connected properly, if it all appears to be connected in the right places & still not working, check to see if it's getting any voltage coming through when you switch positions.
