Coolant leak detector fluid
haydn callow
Post by haydn callow » Wed Jan 07, 2009 11:05 pm
A couple of forum members have suggested that it would be a good thing to have a supply of Coolant leak detector fluid available to the membership.
As it is fairly expensive to buy a small quantity for personal use I have taken it upon myself to buy a "bulk" 'ish
amount which I will pass on at cost price. It will be supplied in 1 fluid ounce "shots" I understand a V6 requires a half ounce shot per treatment. It will not affect the colour of your coolant and can stay in the coolant for 2 years. As well as the dye you will need a UV torch such as
http://cgi.ebay.co.uk/2-Modes-41-LED-To ... 240%3A1318
The cost of a 1 ounce shot will be £5.50 delivered.
Let me know
Oh !! the fluid is Tracerline 3940
Oh ! Oh ! I should have it within a week
http://www.coolantalarm.co.uk
Also BMW Clocks
Re: Coolant leak detector fluid
Post by mikeonb4c » Wed Jan 07, 2009 11:15 pm
Count me in Haydn and thanks - a brilliant idea. I think you can count Ronhud in too as he has previously expressed interest. 8) We are both expecting to do a coolant change when the weather improves and we can be a*sed :lol: :lol: :lol:
ronhud
Post by ronhud » Wed Jan 07, 2009 11:26 pm
Yes Mike is right - I still have to top up after a long(400) mile trip, Haydn's alarm always alerts me. So whats the payment method?
Ron
haydn callow
Post by haydn callow » Wed Jan 07, 2009 11:30 pm
will post on here when I have it to hand (next week hopefully)
Also BMW Clocks
haydn callow
Post by haydn callow » Thu Jan 08, 2009 10:41 am
There is now a delay in the delivery of this.....could be 2 weeks....watch this space
Also BMW Clocks
Ron Miel
Post by Ron Miel » Thu Jan 08, 2009 10:43 am
Just to confirm that Haydn's right, and there is active interest in addition to those above, I already ordered my 1 oz from him. Looks a brilliant idea. I happen to know that Haydn's also buying in at least one 8oz bottle, suitable for dealer/garage multi-applications. Dosage is 1 oz per 6 US gallons of coolant, which means about 0.6 oz into the 13 litres of a V6 cooling system (1 US gallon = 0.3785 litres).
For larger quantities for trade use (and to give some promo balance here), find the UK distributor, Autoclimate nr Shrewsbury, online - they do only offer larger trade quantities though.
Veg_Ian
Post by Veg_Ian » Thu Jan 08, 2009 10:53 am
How's that work then? Is it a fluoresceine type product (bright green, glows in the dark)? Not sure why you need it. Isn't a puddle or tell tale signs of dried antifreeze enough?
haydn callow
Post by haydn callow » Thu Jan 08, 2009 11:05 am
If you have a "proper" leak..then yes, you may well see a puddle. However often your system will only have a "weep" or indeed only leak when up to temp and pressure. This is where the fluid comes in....it glows when a UV torch is shined on it. It will be handy for those that have to top up every few weeks and they don't know where it's going.
The company mentioned above don't have it in stock at the moment...3/4 weeks delivery....I have some on the way from the States and a bottle from the above being ordered. If there is a gang of you it would be a little cheaper to club together and get your own. I have to add on the P&P to get it to you.
Also BMW Clocks
haydn callow
Post by haydn callow » Thu Jan 08, 2009 11:07 am
Here we go again...I'm doing this as a service to members and not making profit.
What is your problem with me ??
Quite happy to cancel the arrangement if you instruct me to do so.
Also BMW Clocks
Ron Miel
Post by Ron Miel » Thu Jan 08, 2009 11:07 am
Veg_Ian wrote:How's that work then? Is it a fluoresceine type product (bright green, glows in the dark)? Not sure why you need it. Isn't a puddle or tell tale signs of dried antifreeze enough?
If you get as much as a puddle (you certainly don't then need any aids!), or if you can see see smaller leaks in the general grime and/or darkened inner recesses of an engine bay! Coolant with the dye added fluoresces (wet or dry) under UV, or (in the case of TP-3940) any fluorescent inspection lamp, while surrounding areas remain dark - true UV is beyond the wavelength of visible light. The fact sheet on overheating problems has photos showing how very hard to visually detect leaks otherwise can be.
haydn callow
Post by haydn callow » Thu Jan 08, 2009 11:08 am
Ian (Bongo master)please sort this out one way or 'tother
Also BMW Clocks
Ron Miel
Post by Ron Miel » Thu Jan 08, 2009 11:12 am
haydn callow wrote:Here we go again...I'm doing this as a service to members and not making profit.
Don't rise to it, Haydn! Just ignore it.
Doesn't it occur to people that, as well as an invaluable and generally friendly/constructive resource, this forum is just one huge advertisement. I've lost count of the number of purchases I've made from Maynards of Wetswick (and all power to their elbow too), who I would not even have heard of without this forum. I don't think Ian does a lot of advertising, or probably selling, outside of it.
haydn callow
Post by haydn callow » Thu Jan 08, 2009 11:20 am
O.k. My investment in this fluid to date is £97......I will be pouring it down the drain on receipt..
Well done Keefysher....you really are somthing else.
Those who have asked for some...send me your address and I will give you some.
Also BMW Clocks
bongoing-mad-simon
Post by bongoing-mad-simon » Thu Jan 08, 2009 11:23 am
Good on you Haydn for yet again offering a brilliant service to Bongo owners ,By ordering a bulk amount of this product and opening up opportunities to people that otherwise may not be able to access them =D> =D> =D> =D> =D> =D> .
I must say reading the forum recently is becoming a bit of a drag with some people constantly making as what I read as digs at you for no apparent reason ,and some of these have been in incredibly bad taste :x :evil: ,I hope that this thread is not going to go the same way. As far as I have read Hadyn is passing on at cost price no selling or profit making here, this has been done by others recently, with wheel arch spats and wind breaks by buying bulk it is helping not so well off people this is to be commended =D> ,it doesnt seem to be what is being done that Keith as a problem with but who 's doing it :evil: Haydn please ignore these attacks as far as I am aware you are highly respected by forum members and it would be a real shame to waste this product and idea.
Simon
I'm Bongoing mad R U?
platty345
Post by platty345 » Thu Jan 08, 2009 11:26 am
Wasn't the wheel spats a one off , This guys as been knocking out gear week in week out it seems,
