Or the little hole in the filler cap.francophile1947 wrote:Or the sealsscanner wrote:Must be moisture getting in through the pipes.![]()
banjo filter needed quick.....
Re: banjo filter needed quick.....
Is that the one with the extractor fan?scanner wrote: Or the little hole in the filler cap.
So, where does the stuff that blocks the banjo strainer come from?
Dunnofrancophile1947 wrote: So, where does the stuff that blocks the banjo strainer come from?
Definitely notscanner wrote:if it can block the strainer you don't want it going through the pump do you?
- dandywarhol
It's probably fibres from the fuel filter....................
bongomaan
thats a thought it could be moisture coming in through the leaky pump seals,if i hear back from lawson diesel i"ll order some,been putting it off but its looking like a whole weekend on the bongo next weekend,(banjo/pump seals/glow plugs/and two sensors to check) will it ever end ??????......
The "banjo" filter is the last line of defense before any contaminants enter the pump, anything trapped by the filter could eventually gum up the injectors....
(why does the shocked emoticon now look like a constipated alien?)
Perhaps it IS a constipated alien, after it saw your orange wigbigdaddycain wrote:(why does the shocked emoticon now look like a constipated alien?)![]()
I'd have thought the image of me donning my carrot top would have made anybody 5h1t themselves...be they human or not john!
Hang on a mo... Nah, this one's gotta be the alien in need of relief:
Yep - I reckon it's how he/she (gotta be politically correct
) looked just before filling their pants
The last of these assortments would be handy for any one intending to clean their Banjo filter to have around, in case one of the washers goes walkabout.
http://www.aldi.co.uk/uk/html/offers/58_8707.htm
- dandywarhol
Never heard of "zinc-plated A3 hardened steel" fibre washers before.....................
ANDdandywarhol wrote:Never heard of "zinc-plated A3 hardened steel" fibre washers before.....................
If they were A3 in size you'd have a job getting them into place.
I think that bit should have been inserted above the washers.
I think the grommets should be below that as well - I don't fancy cables chafing on zinc plated steel grommets.
