Timing Belt Change, Now Power Loss.
Retro Bates
Post by Retro Bates » Sat Jan 31, 2009 4:07 pm
I just had my belt changed and driving home was peculiar. A distinct loss of power and it seems to fail to reach top gear. It's a 2.5 Auto It struggled up a hill at 2600 and 40mph.
I know he has done something wrong, but what and how easy will it be to remedy?
westonwarrior
Re: Timing Belt Change, Now Power Loss.
Post by westonwarrior » Sat Jan 31, 2009 4:15 pm
sounds like the timing is out. I would take it back and get it checked
Dolly1
Post by Dolly1 » Sat Jan 31, 2009 5:37 pm
Maybe the pipe from the turbo dislodged
SARAH & LIONEL - I Used to be Citroen 2CV "DOLLY" mad but BONGO-MAD lady with not so mad husband now!
Post by francophile1947 » Sat Jan 31, 2009 5:39 pm
Also, if the timing is out (which it sounds like it is), you'll probably need a new timing belt, as it's not wise to refit them after they've been used.
Post by mikeonb4c » Sat Jan 31, 2009 6:37 pm
Dolly1 wrote:Maybe the pipe from the turbo dislodged
Beat me to it. On more than one occasion (one of them very recently), this little pipe has not been replaced after work done on engine, with resulting symptoms just like what you've described. 8)
scanner
Post by scanner » Sat Jan 31, 2009 6:37 pm
francophile1947 wrote:Also, if the timing is out (which it sounds like it is), you'll probably need a new timing belt, as it's not wise to refit them after they've been used.
And that's the mechanics problem.......................................
Retro Bates
Post by Retro Bates » Sat Jan 31, 2009 7:26 pm
And where might I find this culprit. A piccy would be magic.
Post by mikeonb4c » Sat Jan 31, 2009 7:28 pm
Retro Bates wrote:And where might I find this culprit. A piccy would be magic.
Ya got me there but one end presumably attaches to the turbo. No doubt some wag will be along with the answer shortly but have a search on here meantime as that may turn up some info (can't remember if there ever were piccies :roll: )
dandywarhol
Post by dandywarhol » Sat Jan 31, 2009 7:46 pm
I know theres some discussion about reusing/retensioning timing belts and I go along with it with the serpentine belts on modern twin cam diesels driving other appliances too but the Bongo is a low torque setup and I'd happily refit and tension it again.
Here's the pipe - see both ends are connected - ignore the swollen coolant pipe - its foobared
Retro Bates
Re: Timing Belt Change, Now Power Loss. SORTED
Post by Retro Bates » Sun Feb 01, 2009 12:23 pm
Thanks for the suggestions and support.
I took a look at the pipe pictured, and this led me to the problem. It was indeed a pipe that wasn't connected, the big air pipe over to the right. Five greasy fingers later, I am back on full power. Happy Days!
So I can now happily tick a few jobs off my list.
Fix Broken Manifold Stud
Change Timing Belt
Change Top Hose. my old one looked exactly like the one in the picture, ready to blow!
Fit Coolant Alarm
January was a good month for my Bongo.
Post by missfixit70 » Sun Feb 01, 2009 2:12 pm
Nice on, simple fixes are happy fixes :D Did you do the manifold stud yourself? Hopefully see you guys at the Wokey Hole meet :D
Retro Bates
Post by Retro Bates » Sun Feb 01, 2009 3:56 pm
Haydn's friend did the stud and all the belts including the cambelt. I bought the parts, Labour was £120. which I think is pretty good for two very tricky tasks.
Post by mikeonb4c » Sun Feb 01, 2009 4:20 pm
Retro Bates wrote:Haydn's friend did the stud and all the belts including the cambelt. I bought the parts, Labour was £120. which I think is pretty good for two very tricky tasks.
Unbeatable I'd say - who'd want a new car and main dealer service prices after a result like that...is what I say!
Great news about the pipe too. 8)
haydn callow
Post by haydn callow » Sun Feb 01, 2009 4:39 pm
This friend of mine FRANK (I play golf with him) has been a vehicle/bike mechinic all his life and is now semi retired.
He will do the best job he can at a very reasonable rate...Do NOT expect a posh garage..He now works at the back of a Pig farm out of a large shed (you can get a Bongo in) with another guy who does small bodywork jobs and spraying. All is cash in hand and cover your seats with a old sheet.
Having said that ...so far he /they have done my No1 stud and cambelt..Retro Bates as above and sprayed my bumpers and lower bodywork...They are cheap as chipsand so far so good. They operate 10 miles from Yeovil near Somerton/Langport.
As a matter of interest...Frank noticed the Cambelt factsheet says about 2 hours....he is no slouch but reckons quite a bit longer
Pity he left the air pipe off but better men than him have done that...no harm done...hey ho!!
http://www.coolantalarm.co.uk
Also BMW Clocks
dandywarhol
Post by dandywarhol » Sun Feb 01, 2009 7:27 pm
You're right - anyone can make a mistake but there's no excuse for not road testing it after the works been done! (IMO)
