no, bdc
i have a bottle of diesel with a clear pipe connected direct. Takes the filter out of the equation.
i have just removed the solenoid. tried starting it without the spring and plunger Gary said to take out. The pump sucked the diesel out of the bottle, but not at a very powerful rate. It sort of went up the tube and then came back down again. I don't know what all of this means.
In order to get to the solenoid, I had to remove the top set of fuel injector pipes. So while they were out, I blew through them. No blockages there.
Gary, Ravenhill Road.
picture below.
onilleymcknown.
Did it start?.........Did all the fuel drop back or was it a big bubble of air travelling down the pipe?....have you disconnected an injector to see if fuel is pumping from the bottle out of the pump?
