Another glowplug/relay problem!!
Wi11iBongo
Hi Guys, Had an accident with the glowplug rail and earthed it out. Dash light comes on and off as normal. It is a 2000 2.5, there isnt a fuse wire from positive battery connection (revision i guess) so my question is will it short out the relay or is there a fuse inbetween? I can't see anything in the bongo and I can't see anything in the members area.
Any help greatly appreciated.
- westonwarrior
Re: Another glowplug/relay problem!!
there must be a fuse somewhere
tip put location on your profileand maybe some local advice can come forth like who to take it to to get it checked
Fusible link - see http://www.igmaynard.co.uk/bongo/forum/ ... nk#p271645 and other threads - just search for fusible AND link
Try fuse No18 10amp..
Cheers Malc..
Cheers Malc..
- haydn callow
Spot on teenmal....and no fuseable link
haydn callow wrote:...and no fuseable link
- haydn callow
Some seem to have them and others (mine included) not
Well, you live and learnhaydn callow wrote:Some seem to have them and others (mine included) not
Wi11iBongo
Thanks for the replys guys, I should have said before fuse 18 is ok too, checked all fuses under dash.
In that case, you may well have a blown fusible link.
Wi11iBongo
Don't think there is one, nothing running from the positive battery terminal.francophile1947 wrote:In that case, you may well have a blown fusible link.
Pity - that would have been nice and easy
Do as westonwarrior said and put your location in your profile - somebody local may well be able to help
Hi it might be worth checking fuse No6 20amp under the hood,just in case you have a later spec vehicle..
Cheers Malc..
Cheers Malc..
Wi11iBongo
Again thanks for the replys, realy appreciate the help. I've now checked all the fuses and they seem fine. I have got a replacement relay on the way, I can only think it's fused itself into the off position, but then maybe the dashlight wouldnt light up!!??!! Ah well I will have a better idea when the relay arrives!.
Hi you might have blown the wire from the relay to the GP railWi11iBongo wrote:Again thanks for the replys, realy appreciate the help. I've now checked all the fuses and they seem fine. I have got a replacement relay on the way, I can only think it's fused itself into the off position, but then maybe the dashlight wouldnt light up!!??!! Ah well I will have a better idea when the relay arrives!.
