bongo turning but not starting - any ideas
- missfixit70
Re: bongo turning but not starting - any ideas
Posted most of it on thursday
Good to know we're all reading form the same sheet though
bennett
- Junior Bongonaut
Hellooo, thank you all so much for all our help and tips, greatly appreciated. We managed to borrow another glow plug rail from a fellow bongonaught and hurrrray!!!!!! it works fine. So first thing tomorrow we will be ordering a new part.
Thanks again from sunny copplestone
Tracy
ps did any of you watch the rugby yesterday? Neil happy England won but I'm sad Wales lost!!!! but good game!
Tracy
- missfixit70
Glad you're sorted
- dandywarhol
If you can't start it cold then how are you going to start it scarlet.........scarlet wrote:Hi a good diesel should start with out the glowplugs as they only warm up the air in the bores and you only realy benifit from this when its cold.Have you got 12v going to the glowplugs if you have a pre 2001 i think its fuse 18 on the internal fuse block i think it's a 10amp fuse. The relay only operates for a few seconds only when you turn the ignition on so it will take two people to test enless you remove the relay and make up some lead to test it with.Have you got 12v going to the stop solinoid hope this helps.
cheers
martn
A cold indirect injection engine will have a real difficulty statring - even in summer, so glowplugs are essential.
Although the glowplug warning lamp goes out after a few seconds, the Bongo plugs stay on for 15 seconds with just the "ignition" on, otherwise when the engine is started the timer relay can keep them on for several MINUTES depending on the ambient temperature.
Excellent. Did I read on here something about the glowplug rail shorting out on glowplugs if incorrect length glowplugs were fitted. I'm not suggesting it has anything at all to do with this problem, but I never read on here before of a faulty glowplug rail. I assumed it was just a metal strip that made sure they are received electric power, but I'm no techie and have never fiddled with minebennett wrote:Hellooo, thank you all so much for all our help and tips, greatly appreciated. We managed to borrow another glow plug rail from a fellow bongonaught and hurrrray!!!!!! it works fine. So first thing tomorrow we will be ordering a new part.
Thanks again from sunny copplestone![]()
Tracy
- missfixit70
I reckon they probably meant glow plug relay Mike.
I love you Kirsty - you're so clevermissfixit70 wrote:I reckon they probably meant glow plug relay Mike.
- missfixit70
I suspect you're rightmissfixit70 wrote:Aw shucks
Had me confused too, I might be wrong in my assumption though
No matter how painful it is, i have to agree with dandy heredandywarhol wrote:If you can't start it cold then how are you going to start it scarlet.........scarlet wrote:Hi a good diesel should start with out the glowplugs as they only warm up the air in the bores and you only realy benifit from this when its cold.Have you got 12v going to the glowplugs if you have a pre 2001 i think its fuse 18 on the internal fuse block i think it's a 10amp fuse. The relay only operates for a few seconds only when you turn the ignition on so it will take two people to test enless you remove the relay and make up some lead to test it with.Have you got 12v going to the stop solinoid hope this helps.
cheers
martn![]()
Ultra efficient common rail fuelled diesels can start cold without the aid of a pre-warmed combustion chamber,but an indirect injection old lump as fitted to the bongo just won't start cold without the help of the glowplugs. The compressed fuel vapour heats as it's compressed, but can't achieve flashpoint temperature inside the dense cold walls of the combustion chamber without help from the warm air generated via the glowplugs. Notice how difficult it is to start a stone cold engine with just one lazy plug?
