fuel tank full - gauge not
ronhud
The last two times I have filled up with diesel I have run the pump until it clicked off automatically and then continued filling until the level looking down into the filler tube seemed to be a few inches below the top. But then when I switched on the ignition and let the gauge rise ( which is very slow) it only reached the 3/4 mark. Before filling the gauge pointed at the thin marker on the left and to my surprise it only took 20 litres to being full - anyone else experienced this and any ideas of the cause/solution.
Ron
Ron
- haydn callow
Re: fuel tank full - gauge not
You probably need to put a new earth wire on the sender unit...common fault....easy fix.
Has your gauge always behaved this way Ron? Mine has always only indicated 3/4 full, till i get about 10 minutes down the road, when it then shows up as brimmed on the gauge... I just put it down to bongo quirkiness...ronhud wrote:The last two times I have filled up with diesel I have run the pump until it clicked off automatically and then continued filling until the level looking down into the filler tube seemed to be a few inches below the top. But then when I switched on the ignition and let the gauge rise ( which is very slow) it only reached the 3/4 mark. Before filling the gauge pointed at the thin marker on the left and to my surprise it only took 20 litres to being full - anyone else experienced this and any ideas of the cause/solution.
Ron
Seens were on the subject of fuel gauges mine seems to run for ever on empty
infact the needle drops below the red reserve
thats when i fill up
no matter how long i keep it on the red there always seems to be 10l of petrol left in it when i top up, is my gauge faulty guy's
or is it as bdc say quirkiness
Dar
Dar
ronhud
BDC - no it has only just started to work like this. It has always taken a few minutes to register full properly but now it never reaches full. I'll follow up Haydn's tip - I guess the sender is somewhere on the fuel tank so I will have to jack up the back end.
Ron
Ron
- haydn callow
The sender is...slide the middle seat as far back as you can.....pull the carpet towards the middle from the drivers side....you will see a metal plate in the floor......it's under that....dead easy.
Kirsty has a photo somwhere.
- missfixit70
Here you go -
ronhud
Hey guys - what a cracking response - many thanks
Ron
Ron
David Edwards
Why not make this sticky, it is happening more and more and loads have asked about it recently,with those cracking photos it makes it so easy to locate and rectify.
- missfixit70
We'd end up with too many stickies if that theory was applied across the board.David Edwards wrote:Why not make this sticky, it is happening more and more and loads have asked about it recently,with those cracking photos it makes it so easy to locate and rectify.
The FAQ section at the top of the forum is gradually being updated to include as many of these more common problems as possible, & the factsheets are also gradually being expanded.
Mike&Katie
I've just had this issue, but sorted it out by following the pointers from here. just connected a new earth wire from the old to one of the screws that hold the fuel tank inspection plate on. i now have a full tank!
Mike.
Mike.
ronhud
Update - problem fixed with the help of the info posted on this thread, thanks.
Question - I assumed the 'clamp' like thing was the earth but I've not come across this device before. How does it work, is the spiral outer sheath an earth wire? I couldnt find anything the clamp had been fixed to so how did it funtion before it stopped?
Ron
Ron
wend1968
thanks guys. great pics too. will have a look on weekend and let you know how I get on. Cheers everyone.
ronhud
The assumption I made in my earlier post was.... mad! I subsequently found that one of the 2 wires was the earth and used spade terminals to connect it to a short length of wire earthed to a screw in the inspection plate.
Ron
Ron
