Space saver tyre?
georgey
Space saver tyre?
Post by georgey » Fri Mar 27, 2009 10:58 am
Hi guys, reading all the recent threads regarding the space saving tyre being used along side 17 or 18 inch wheels is there any point in carrying it or would it be better to get a normal size spare wheel if so what size? I have 215 55 17 inch tyres on alloys at present and a 2wd Bongo. Any advice appreciated...regards Geoff.
motorwizard
Re: Space saver tyre?
Post by motorwizard » Fri Mar 27, 2009 11:08 am
No matter what the rim size the spare should have the same circumference. I have alloys and have a steel rim wheel and tyre as spare. A full size spare will fit the carrier and give peace of mind if you have a puncture.
David Edwards
Post by David Edwards » Fri Mar 27, 2009 11:22 am
It should be called a waste of space saver tyre, it really is pretty useless, mine is on the drive waiting to go up the tip, I got a full size and it fits perfectly, peace of mind too but . as a braces and belt I also carry a tin of instant repair stuff just in case it is not safe (motorway) to change at the time.
stilldesperate
Post by stilldesperate » Fri Mar 27, 2009 12:52 pm
georgey wrote:I have 215 55 17 inch tyres on alloys at present and a 2wd Bongo. Any advice appreciated...regards Geoff.
Bin the spacesaver !
Look for a 215/65 x 15".
The rear std wheel (215/65 x 15") will be fine, it's a closer rolling circumference that the std front (195/70 x 15").
See http://www.tyresave.co.uk/tyresize.html
SD
"The older I get, the faster I was"
Ron Miel
Post by Ron Miel » Fri Mar 27, 2009 3:33 pm
georgey wrote:Hi guys, reading all the recent threads regarding the space saving tyre being used along side 17 or 18 inch wheels is there any point in carrying it or would it be better to get a normal size spare wheel if so what size? I have 215 55 17 inch tyres on alloys at present and a 2wd Bongo. Any advice appreciated...regards Geoff.
Another good reason to stick with the original steel wheels?
David Edwards
Post by David Edwards » Fri Mar 27, 2009 3:52 pm
Jolly Rogers was giving one away, ask nicely lol.
Post by Doone » Sat Mar 28, 2009 9:50 pm
If J.R still has it, the offer is here.
