would this be any good till i get a leisure battery fitted ?
ebay item
300307658555
solar charger
Bhongo Bhoy
Re: solar charger
Absolutely useless
2.4W, which will be it's maximum output when facing the sun on a sunny day, is not even enough to power an interior light (not that you'd need an interior light when the sun was shining
). It certainly won't replace much of what you use from your main battery.
- peanutcrusher
- Tribal Elder
Re: solar charger
try here its cheaper
http://www.maplin.co.uk/Module.aspx?ModuleNo=223251
or here are the others they do
http://www.maplin.co.uk/Search.aspx?menuno=13001
Bongo now work later !!!
Re: solar charger
It might be cheaper, but it's still useless
10 hours of blazing sunshine would be about the same as running the engine for 2-3 minutes.
Re: solar charger
i bought a 15watt one just to help top up the leisure battery whilst its stood doing nowt.
there on specially offer now too, £34 off.
http://www.sunshinesolar.co.uk/khxc/ind ... grhj8la1yc
Bhongo Bhoy
Re: solar charger
i think ill give it a miss then
whats the best way of going about getting a leisure battery fitted ?
can you buy a kit with everything you need and if so from were as i cant find it in the bongo shop
Re: solar charger
Ebay item number 220395522126 is what you want if you have a diesel automatic. He also does the battery tray as a kit. Dead easy DIY kit.hhc wrote:i think ill give it a miss then![]()
Two tonne tin drum
