And the moral of the story is keep away from the contacts with your spray grease.
Yeah, same principle.bigdaddycain wrote:I see...Like the springy contact at the base of a bulb? Prise it upwards..Better contact?
My roof light started to flash again and the beeps when i started the engineScubaBongo wrote:Fixed mine too, using a cut down version of Bongo Boozers solution:
1. Open roof half a meter.
2. Locate the microswitches- you can see them on the underside of the roof panel if you stand on drivers/passangers seat.
3. Loosen the 2 screws in the yellowy-white component of the switch. Push this part towards the black switch. Re-tighten screws.
Done!![]()
Thanks all, another job sorted.
