spare bits 'kit' to keep in the back
jed1y0da
Post by jed1y0da » Mon Jun 01, 2009 9:48 pm
Hi, I'm new to bongos and new to the forum, so hello :)
I have a very 'basic' newbie question: I've just bought a bongo and was wondering what sort of spare bits (fuses etc ) to keep in the van for any fixable roadside emergencies?
any suggestions?
Thanks in advance!
Re: spare bits 'kit' to keep in the back
Post by mikeonb4c » Mon Jun 01, 2009 10:17 pm
jed1y0da wrote:Hi, I'm new to bongos and new to the forum, so hello :)
any suggestions?
Thanks in advance!
Ah yes, I ask myself that (esp. if I was to travel somewhere like Europe where spares might be trickier). But how long is a ball of string. One or two thoughts:
* Some of that self annealing tape that can be used to temporarily fix a leaking coolant hose
* The coolant system bleeding instructions (in case it has ot e bled by a garage unfamiliar with Bongos)
* Some rope for lashing the AFT down should the mechanism fial when lowering it, plus the instructions on what to do and a suitable allen key for unbolting the motors.
* A set of belts (2 x alternator and 1 x aircon compressor)
* Some spare bulbs
* Some spare 50/50 coolant mix (in case you get a slow leak - you have fitted a low coolant alarm to warn you in time haven't you?)
* Jump leads (you can store them under the bonnet) as you can't bump an automatic
* Maybe identify the most likely to go coolant hoses and have those on board
* Some fuses
That's enough from me I think 8)
Post by g8dhe » Mon Jun 01, 2009 10:46 pm
The Bongo club shop above does Bulb and fuse kits, I keep a toolkit in the Van, Gaffer tape, Tent repair tape, Fuse and electrics diagram ( laminated ) & spare bulbs for the tow bar / back box lamps.
Post by Bob » Mon Jun 01, 2009 10:57 pm
In addition to all the above, tow rope, gripper pads to get you started on a muddy field, Good Beer Guide, Camping Club book, toilet and roll, brew kit, fire extinguisher, first aid kit, heavy gloves, latex gloves, blanket, change of clothes, camping stools, wellies...
mikexgough
Post by mikexgough » Tue Jun 02, 2009 6:12 am
I also carry a litre of engine oil in addition to bits n bobs already mentioned
Post by Muzorewa » Tue Jun 02, 2009 8:26 am
Don't forget some bottled water and a couple of tins of Spam in case you get stranded for a while :wink: :lol:
apole
Post by apole » Tue Jun 02, 2009 10:39 am
Also consider:
Set of disposable latex gloves
Handwipes
First aid kit
Torch
Make sure your wheel nuts can be undone too, sometimes they are way too tight to remove with the supplied wheel brace, and/or the wheels have corroded onto the hub so you can't get the wheel off if you need to.
jed1y0da
Post by jed1y0da » Tue Jun 02, 2009 12:12 pm
wow - thanks for all the info!!
Post by mikeonb4c » Tue Jun 02, 2009 1:27 pm
Oh, nearly forget:
Soap on a Rope
:lol: :lol: :lol:
Aethelric
Post by Aethelric » Tue Jun 02, 2009 2:19 pm
any suggestions?
Thanks in advance!
* Some spare bulbs
* Some fuses
Hi Mike
The self annealling tape gets very soft and strechy when it gets hot. I don't think it would hold a leak. If you have some, wrap a bit around your top hose and see what its like when its hot.
Dave
Post by mikeonb4c » Tue Jun 02, 2009 4:41 pm
any suggestions?
Thanks in advance!
* Some spare bulbs
* Some fuses
Hi Mike
Dave
Can't remember exactly what tape it was but it was someone else on here who was talking about (self annealling I thought but could be wrong) radiator hose repair tape. I guess it must be a type that cures with heat. I think it was on the Halfords website (among others) so I'd suggest they have a search there 8)
