lowering bongo suspension
Richard hird
Does anyone out there no where to get a set of lowering springs and shocks to help reduce pitch and roll. Thanks Rich
- peanutcrusher
- Tribal Elder
Re: lowering bongo suspension
bell hill garage sell them they are in bath. spoken with them a few times very helpful.
Bongo now work later !!!
Be careful if yours is 4WD, as you can end up with front drive shaft problems - do a search and check out Bigdaddycain's post on the subject.Richard hird wrote:Does anyone out there no where to get a set of lowering springs and shocks to help reduce pitch and roll. Thanks Rich
Richard hird
Thanks for the quick replies. it is a 2wd and has 19" alloys
- maxheadroom
What tyres?Richard hird wrote:Thanks for the quick replies. it is a 2wd and has 19" alloys
Richard hird
it has 235x40 tyres
the janner vanner
Your Bongo sounds as if it has been pimped a tad, any chance of a picture? and could you please give your location, as this helps the anoraks point you in the right direction as to where is the best place to find parts etc
The Janner Vanner
Richard hird
it has been pimped a bit, just not quite enough yet. I'm in Harrogate, N.Yorkshire. I'm new to this so i'll try and get some pictures posted shortly.
- oxfordpaul
- Bongonaut
Dude is there any room to lower your bus? those rims must be really filling the arches
Any fool can make things complicated, it takes real genius to make things simple
Richard hird
yeah there' s enough space to drop 40 t0 45mm, thr tyres are a 35 not a 40
Richard hird wrote:yeah there' s enough space to drop 40 t0 45mm, thr tyres are a 35 not a 40
Are those tyres up to spec on load index?
At least 92 front and at least 96 rear?
Some folks have reported problems with under-rated low profiles.
Richard hird
yes they have mate. the first set split, almost like someone had slit them with a stanley knife. makes them expensive though
