Soft pipe connecting to radiator
Nick65
Re: Soft pipe connecting to radiator
Post by Nick65 » Sun Jun 28, 2009 6:23 pm
#-o #-o #-o
For some reason when I wrote the last couple of times my computer did not show many replies, which was confusing as half the things did not make sense.
My apologies for that -I was not ignoring your advice
Thanks anyway =D> =D> =D>
Post by francophile1947 » Sun Jun 28, 2009 6:30 pm
Nick65 wrote:#-o #-o #-o
Yeah yeah - where've we heard that one before :lol: :lol: :lol: :lol: :lol: :lol:
Post by Ian » Sun Jun 28, 2009 7:55 pm
Newsflash! Bongo Shop now stocks the 5 most problematic hoses.
Non members http://www.igmaynard.co.uk/bongo/mercha ... tm#Coolant
Members http://www.igmaynard.co.uk/bongo/member ... tm#Coolant
Nick65
Post by Nick65 » Sun Jun 28, 2009 11:31 pm
The only problem I see about that diagram is that I cannot understand it!! :? :? :?
Where are the pipes supposed to go to??
Post by missfixit70 » Mon Jun 29, 2009 12:33 am
If you mean the lushprojects diagram, Y goes to the top of the radiator, Z goes from the bottom of the radiator, X goes to the bottom of the thermostat on the passenger side of the engine & 15-186 goes to the top of the engine on the drivers side - this is the one that started this saga :wink: Check the link that Ian posted to the club shop, prices a bit better than Bongobits if you're a member, the main offending hose is the 4th one down on his listing, the three above it are the three others mentioned above.
It may be as well to replace the hose that goes over the starter motor to the rear heater from the engine too, Ian or Bongobits or Flippa (ebay silicone hoses) will know what you mean, also while you're at it, it's probably be worth changing the stat & make sure he does a proper flush - preferably with the stat out ( just make sure it goes back in :wink: ) & backflush the rad.
Make sure he gives you some of the same coolant to top up with, should you need to & I would highly recommend getting a Mason or Coolant alarm fitted if you don't already.
Nick65
Post by Nick65 » Tue Jul 14, 2009 9:38 am
My mechanic is currently changing all 4 pipes
Many thanks for all your help
Nick
