Just failed the dreaded Ministry of health on a worn lower ball joint, bah! I have a fortnight or so to get it done before the MOT I have runs out.
I would like to ask if anyone has found a compatible part for the ball joint, I was wondering if a transit or ranger or B3000 part might fit. I have seen the bongo ones for around £40 but wondered if there might be an alternative as transit ones are about 25 quid cheaper, and look similar in photos, not the best way to choose a part I know as it is necessary to be smack on for safetys sake, but I wondered about taking my engineering measuring kit to the local factors to compare other joints with my to-be-removed joint. Is it that easy to replace the ball joint in the arm? I thought of warming the arm up to remove and replace the ball joint, using the blowlamp. I have had a browse through previous posts but did not see alternative parts mentioned. Any advice gratefully received........ now where's the wheelbrace...
Hope you are all enjoying the summer nights out and about.
Richie
