Unkown device - help needed?
hello
Help needed: after disconnecting the main battery to recharge it and then reconnecting it, I now have a constant bleeping noise.
The sound is coming from a device below the steering wheel, can anyone tell me what this black box is for? And how I may reset it to stop the bleeping, picture of the black box on the link below
http://s1023.photobucket.com/albums/af3 ... evice2.jpg
thanks
thanks
- westonwarrior
Re: Unkown device - help needed?
looks to have an on off switch
Have you tried turning it on then off?
Last time I saw one of those was in a James Bond film - when it stops bleeping - run!
I would say that its a turbo timer or one of the headlight dimmer things
Does the red light flash too..?
no flashing light, just the bleeping. i have tried swithing off and back on again but no luck.
i thought i read somewhere on the site that it may be a remote control starter??
but i wanted to make sure its ok to remove it or leave it off
If it is a remote starter, i don't think it would hurt to turn it off...?
Does it stop beeping if it's switched off then..?
I assume you don't have the remote fob that came with it?
It's connected by wires have you traced them out to see where they go?
Sparky
Sparky
The Bongo has gone. Long live The Bongo
Hymer Camp Swing 544/Fiat Ducato 2.3jtd
yes the beeping does stop when swithed off, the wires appear to go up towards the ignition, not fully traced them yet though
stevec wrote:no flashing light, just the bleeping. i have tried swithing off and back on again but no luck.
thats the thing I thought it could be
So i would say it deffinatly a remote starter as turbo timers have dials or numbers/ buttons to set the timer for the engine to shut down.
If you dont have the fob then you may as well take it out, dont know where the wires would lead to but just disconect it from the conector block and see if your bongo still starts?, gets rid of the beep but the wires will still be conected up to the ignition and starter motor and glow plugs ect.
