injectors
sajafi
injectors
hi all how easy is it to change injectors and is there anything i need to look out for when i do change them
cheers in advance marcus
Re: injectors
I'm no techie on this but (and have a Search on here to see what you can find) from what I've read I'd be careful. I think you have to set up the injector timing etc. afterwards and it has to be just right (plus I've no clue how to do it!).sajafi wrote:hi all how easy is it to change injectors and is there anything i need to look out for when i do change them
sajafi
Re: injectors
cheers for the promt reply will look more into it befor i make a desision
cheers marcus
cheers marcus
renegade
Re: injectors
Hi, changing injectors is not a difficult job really, the biggest thing is to keep the area clean around the injectors when lifting them out [to stop dirt dropping into the head]. There are copper sealing washers to be replaced when refitting the injectors, when this is done, refit the pipes as removed, leave pipe nuts finger tight on injectors, crank engine till fuel appears, stop, tighten pipe nuts, then crank over again and engine will start.
Re: injectors
Renegade - any thoughts on the issue of injector timing, as discussed in this thread?renegade wrote:Hi, changing injectors is not a difficult job really, the biggest thing is to keep the area clean around the injectors when lifting them out [to stop dirt dropping into the head]. There are copper sealing washers to be replaced when refitting the injectors, when this is done, refit the pipes as removed, leave pipe nuts finger tight on injectors, crank engine till fuel appears, stop, tighten pipe nuts, then crank over again and engine will start.
http://www.igmaynard.co.uk/bongo/forum/ ... tor+timing
Re: injectors
You don't affect the timing by just replacing the injectors Mike
sajafi
Re: injectors
thanks very much the lump in my pants has gone now so i will give it a go next week
many thanks marcus
many thanks marcus
Re: injectors
Ah! I think I see. You mean the injectors are just a part within the large injector/pump unit? I've got so used to thinking of 'the injector' as the whole thing, and my experience of any of this is limited to stripping down an Amal carburettor circa 1970francophile1947 wrote:You don't affect the timing by just replacing the injectors Mike
Re: injectors
No - they are the things, in the cylinder head, that the fuel pipes attach to (look a bit like spark plugs in an old petrol engine) - nothing to do with the pump.mikeonb4c wrote:Ah! I think I see. You mean the injectors are just a part within the large injector/pump unit? I've got so used to thinking of 'the injector' as the whole thing, and my experience of any of this is limited to stripping down an Amal carburettor circa 1970francophile1947 wrote:You don't affect the timing by just replacing the injectors Mike![]()
Re: injectors
Think I'll stick to plywood and varnish.......francophile1947 wrote:No - they are the things, in the cylinder head, that the fuel pipes attach to (look a bit like spark plugs in an old petrol engine) - nothing to do with the pump.mikeonb4c wrote:Ah! I think I see. You mean the injectors are just a part within the large injector/pump unit? I've got so used to thinking of 'the injector' as the whole thing, and my experience of any of this is limited to stripping down an Amal carburettor circa 1970francophile1947 wrote:You don't affect the timing by just replacing the injectors Mike![]()
A man's got to know his limitations.
