Hi All. Problem with pulling away from standing start
mike671
Post by mike671 » Thu Jul 09, 2009 8:58 am
Hi there im from the Isle of Wight and have a Ford Freeda 2.5diesel Auto, I had a fault code of 62 with the gearbox solenoids. I have since replaced them, and strainer with new oil and now once warm, it struggles to pull away? it seems fine when cold tho, its fine through the gears just not pulling away. Any help much appreciated! The levels in the gearbox also seem fine.
And well done for doing a site dedicated to bongos and freedas! I love my Freeda camper its great :D just not up hills at the moment lol
mike671
Re: Hi All
Post by mike671 » Thu Jul 09, 2009 1:07 pm
Anyone??
Alison01326
Re: Hi All
Post by Alison01326 » Thu Jul 09, 2009 1:10 pm
Patience, my dear [-X Can't help but the forum does get busier in the evenings when peeps are home from work. Mind you, it's lunchtime now so someone may be along to help you.
A teensy word of advice to make your posts more appealing to someone, if in future when you post, you put an indication of the problem in the title "Hi All" looks a lot less urgent than "Fault Code 62 Solenoid Problem"
Just a thought - not everyone is as unfriendly as me :lol: :lol: :lol: :lol: :lol: Welcome to the forum - you'll get lots of help and advice (and lunacy ) on here.
Alison
mike671
Re: Hi All
Post by mike671 » Thu Jul 09, 2009 1:55 pm
I did notice that when i posted it lol should have put more along the lines off pulling away problem :oops: Anyway thanks for a reply code 62 is fixed its just it wont pull away very well when warm now :( but im sure ill get it sorted somehow
westonwarrior
Re: Hi All
Post by westonwarrior » Thu Jul 09, 2009 2:12 pm
I will change the title for you
I have heard of this before but cant remember the answer some one eill be along soon
Re: Hi All. Problem with pulling away from standing start
Post by Doone » Thu Jul 09, 2009 3:10 pm
Mike671 there's a factsheet on gearbox fault codes in the members area.
mike671
Post by mike671 » Thu Jul 09, 2009 3:51 pm
thanks westonwarrior, i cant seem to find or view the members area though. For anyone that fancies doing the solenoids its not a hard job just very oily, and try and remember where the bolts go. Its just annoying once warm it wont pull away properly now :?
Alison01326
Post by Alison01326 » Thu Jul 09, 2009 7:07 pm
It's on the main www.bongofury.co.uk site but is only accessible if you are a paid up member of the Bongo Fury (you can be a forum user without being a member of the club, but there are certain useful things, including factsheets, as well as discounted parts and bits & pieces, and certain meets, which are only available to club members).
Alison
dandywarhol
Post by dandywarhol » Thu Jul 09, 2009 11:39 pm
if the problem is still there in L hold, which selects first gear and assuming the engine's performing ok, then it could be a torque convertor stator fault - only cure is to replace it
Post by mikeonb4c » Thu Jul 09, 2009 11:46 pm
dandywarhol wrote:if the problem is still there in L hold, which selects first gear and assuming the engine's performing ok, then it could be a torque convertor stator fault - only cure is to replace it
...and where, pray, are you sending this missive from Oh Holy Holidaying One :roll: :lol: 8)
mike671
Post by mike671 » Fri Jul 10, 2009 9:42 am
Ill give that ago tonight and see what happens, As engine seems to be fine its just pulling away thats the problem. #-o
