Greetings Folks,
Having an MOT coming up I was looking at the rear brakes and found one of the 'Park Brake Shoe Holding Spring Pins' is missing.
Item 6 & 7 on Page 262 of the Service Manual.
Could not see them in the Bongo Shop so any help in tracking down replacements would be very much appreciated.
Richard
						Rear Brake Parts
				rwill19050
- mikexgough
Re: Rear Brake Parts
Presumably you mean ....... 26-391 ......?
You might be able to source at a Motor Factor as they usually sell springs and pins and shims for brake systems...... You might have to take one along and match one up with what they have.......
				rwill19050
Thanks for that mikexgough, that's the one, but my manual has different numbering
I will do as you suggest, and take a trip with one in my pocket.
I wouldn't mind betting that things like springs and pins from brakes were the same on lots of vehicles.  If motor factors can't source some possibly a breakers (not necessarily Bongo) might have them.
									1995 N reg 2WD AFT in green/grey
www.whiteroseancestry.co.uk
- You've Been Bongod
halfrauds do a kit with all the pins and springs in for around £10
				rwill19050
Thanks again for the tips folks.
As usual Bongonaughts to the rescue
