Illuminated Cigarette Lighter
Foz.Foz
Post by Foz.Foz » Fri Jul 10, 2009 5:13 pm
Guys,
I have just bought a new cigarette lighter for the Bongo as the old one broke (long story so please don't ask). I have now got my hands on a new one which lights up in the dark =D> .
Now I don't have a problem with fitting it to the existing connections, that's straight forward. The problem I have is, for it to light/glow in the dark, the bulb bit has to be wired to the lighting circuit. Any ideas as to which colour wire this would be under the dash??
Thanks....
Foz
Re: Illuminated Cigarette Lighter
Post by g8dhe » Fri Jul 10, 2009 5:44 pm
OK, well the wire colour is R/B most likely Red/Black, and it goes to many places! It is switched by a relay under the bonnet on the Nearside which is the second one from the rear (depending on model between 2 and 4 relays may be fitted), it goes to all the sidelights and also to the fascia panel and the LCD display on the electronic version of the A/C, all wires are thankfully R/B so I think the best bet would be look for any R/B wire and then test it! It should also go to the radio connector as I recall to dim the display.
daveblueozzie
Post by daveblueozzie » Fri Jul 10, 2009 6:14 pm
Why don't you connect it to the bulb under the centre console, the bulb that lights the ash tray up is connected to the side lights, just test which wire it is then make your connection.
Lost without my Bongo.
Foz.Foz
Post by Foz.Foz » Fri Jul 10, 2009 6:31 pm
daveblueozzie wrote:Why don't you connect it to the bulb under the centre console, the bulb that lights the ash tray up is connected to the side lights, just test which wire it is then make your connection.
Top dollar.... will give that a go
Thanks Foz
dobby
Post by dobby » Fri Jul 10, 2009 6:54 pm
DBO beat me to it, that's what I did worked ok :D
Foz.Foz
Post by Foz.Foz » Fri Jul 10, 2009 8:34 pm
Well I got it fitted in. The new one was slightly bigger than the one I removed and I had to "shave" a little of the dash away to get it to fit snug, but it now works. I'll Do the lighting side of things when the pub doesn't beckon. Thanks for the replies guys.....
Foz
dobby
Post by dobby » Fri Jul 10, 2009 8:47 pm
If it was a halfords one, you may find that the plug in bit is a bit sloppy and when you plug a lead in you don't always get a decent connection.
jaylee
Post by jaylee » Sat Jul 11, 2009 9:20 am
It is possible to take a feed from one of the wires that back-light the blind switches near the lighter socket.. (It's a lot closer.)
I set mine up with a blue led that shines through the green! :D
dobby wrote:If it was a halfords one, you may find that the plug in bit is a bit sloppy and when you plug a lead in you don't always get a decent connection.
Are they still like that?
I remember fitting one of those 10 years back for a phone charger in my old van & had the same problem... :roll:
Foz.Foz
Post by Foz.Foz » Sat Jul 11, 2009 10:43 am
Right guys.......
The fag lighter will glow orange and light fags as intended. Problem now is that which ever adapter i plug in for satnav, Ipod, phone charger etc, they all blow their fuses.
I have a direct wires coming off the starter battery, with an in-line fuse (10amp) on the live.
Any ideas that could help me??
Thanks... Foz
Post by g8dhe » Sat Jul 11, 2009 12:05 pm
Which fuse blows ? The 10A in-line or the individual fuses in the plugs themselves ?
Post by missfixit70 » Sat Jul 11, 2009 12:16 pm
Have you wired the positive & earth the right way around?
Foz.Foz
Post by Foz.Foz » Sat Jul 11, 2009 1:31 pm
g8dhe wrote:Which fuse blows ? The 10A in-line or the individual fuses in the plugs themselves ?
The individual ones.... the 10amp is fine. It is also wired the correct way around :)
Post by g8dhe » Sat Jul 11, 2009 2:13 pm
I would double check that polarity then ! There is no reason for all the devices to blow, unless you have fitted a 24volt battery ....
Foz.Foz
Post by Foz.Foz » Mon Jul 13, 2009 6:14 pm
g8dhe wrote:I would double check that polarity then ! There is no reason for all the devices to blow, unless you have fitted a 24volt battery ....
:oops: :oops: :oops: :oops: Feel a right t!t. I wired it the same as the old one without looking at the polarity. Turns out the terminals needed swapping :oops: :oops: :oops: .
Although, now I have done that and it is wired correctly, some chargers are smoking when plugged in #-o . not sure what it could be?? any ideas
Post by g8dhe » Mon Jul 13, 2009 7:47 pm
Well if they were plugged in previously and didn't blow the fuse (or even if they did) electronics blow quicker than fuses hence why transistors are referred to as 3 legged fuses. The chances are you have damaged those devices probably beyond repair economic repair :-(
Either that or having been plugged into a Cigar lighter that's what they now think they are - Cigars - I can feel a Havana moment coming on ......
