I have had intermitant problems with my van cutting out and stalling on ocassions
Fuel and water issues
Hi all,
.As in driving up to islands and junctions my tickover drops and starts dipping and rising as if lack of fuel
When this starts sometimes the van will cut out as i'm driving along
This happens randomly,but seens to be when on a journey of over say 60 or so miles
never when doing short runs, work ect
Yesterday went to nottingham and after about 70 odd miles started stalling ect. Decided to try and clear any possable rubbish out of fuel system by holding it in gear up to about 4000 rpm,eased off and made no difference, all the time keeping eye on temp gauge which had moved up to 12 oclock.Shortly after normal driving, needle started to rise
Pulled over and the header tank was spitting out water through top overflow pipe
Waited for some time and saw bubbles comming out of top hose into header tank
Topped tank back up after waiting ages and continued on way. On getting to location after strugling at islands as before we parked up for about 5 hours.The water level slowly dropped as the engine cooled
When we set off for home topped back up to normal fill level and carried spare water with us.After about 50 miles temp rose to 12 oclock and same fuel type issues started
We pulled over and let engine cool but no water spat out ect
After letting engine cool down we drove home another 30 or so miles slowly watching gauge slightly rising droping back to normal ect
On getting home we hadn't lost any water or had any bubbling but water level had risen up to top of header tank
Any ideas
I'm worried how much this will cost me ect
Dave
2.5 Diesel.Full Side Conversion
Re: Fuel and water issues
Is there any sign of steam in the exhaust? It rather sounds as if you may have a head gasket problem. You certainly sound as if there is air in the cooling system, so bleed it in accordance with the fact sheet in the Member's Area.
The stalling could just be a blocked fuel of banjo filter, but it sounds as if you may be losing coolant into a cylinder once the engine overheats.
The standard temperature gauge doesn't go above 11 o'clock until the engine is seriously overheating.
Fingers crossed for you, as a new head and gasket costs well over £1000 fitted
- mister munkey
Whats under the seats Dave?
Diesel, V6 or four pot?
Hi franco, my thoughts as well, but there is no steam in exhaust or any difference in the oil either
why would i get two problems at the same time though, or am i just unlucky
Dave
It may be that the two are unconnected.
Stalling could well be due to fuel starvation, especially the little banjo filter on the pump.
The overheating could just be due to a small leak somewhere (have you got a low coolant alarm?) and, as you don't appear to have had serious overheating, you may get away with just bleeding the system
Hi franco, Thanks for the reply, no coolant alarm fitted
I've checked everywhere but cant seem to find any leak, but i do seem to loose a very small amount of fluid ,so i am loosing it somewhere
Dave
Dave
We've just had the head done on ours
If you are worried its gone then see if you can get a sniffer test done, we had a hose go first and then the head went after that.
Don't want to be a prophet of doom. Hope its ok
I've got a coolant alarm on mine and it didn't detect as the system pressurised.
Yes, if you don't have a Mason Alarm fitted so that the temp gauge is modified to actually give any sort of meaningful reading, anything it tells you could be way too late.francophile1947 wrote: The standard temperature gauge doesn't go above 11 o'clock until the engine is seriously overheating.
Thanks for the replies,
I've got to phone my mechanic up to do some tests
Dave
