Fixing rough idle on a 2500cc V-6: finally fixed!
				trevd01
It definitely sounds like the idle control valve. In 'D' stopped with you foot on the brake there is some load on the engine that is not there when in 'P'.  That could easily be enough to cause the problem you describe.
I cleaned the fuel injection system on my son's ancient Golf to solve a similar problem. I'd never touched a fuel injection system before, but it was easy. And it worked.
- dandywarhol
Not a lot...........mikeonb4c wrote:In the old fashioned world, you might try scewing up the tickover stop (oooh matron!) a tad as a get-you-by and if it doesnt leave the tickover too high in P and/or cause a lurch when you put it into D. Dont know what advice Dandy would give on that
- dandywarhol
A couple years back I posted about a rough idling problem in this now-locked thread.
http://www.igmaynard.co.uk/bongo/forum/ ... 43&start=0
Finally got the issue resolved. It turned out that one of the leads in the distributor cap was broken. A new distributor cap, a fresh set of spark plugs and she's running as good as new!
Jim
'97 Bongo V6 AFT
						'97 Bongo V6 AFT
Re: Fixing rough idle on a 2500cc V-6: finally fixed!
Good news... that job took a while.   Without knowing the service history, it sounds like one of those jobs that you have to go through one step at a time until you have solved the problem. (We found the old thread via your link and merged it for you, so all the info is in one place now
 Without knowing the service history, it sounds like one of those jobs that you have to go through one step at a time until you have solved the problem. (We found the old thread via your link and merged it for you, so all the info is in one place now   ).
 ).Allans Garage retired. Try PGS (Plymouth Garage Services) or Mayflower Auto Services Plymouth
It took so long to fix because I just kept procrastinating till the problem got too annoying to ignore. The solution came by asking my Mazda mechanic of all people
   He recommended changing the spark plugs and at that time discovered the broken distributor cap!
Thanks for merging the thread.
  He recommended changing the spark plugs and at that time discovered the broken distributor cap!Thanks for merging the thread.
Jim
'97 Bongo V6 AFT
						'97 Bongo V6 AFT
