Central Locking Key Remote
MintyMat
Post by MintyMat » Fri Jul 17, 2009 11:30 pm
Hi, I've central locking and a remote key fob but it's starting to play up. The "unlock" button always works but the "lock" hardly ever does. Can I get a replacement remote cheaply or do I need to get the whole system rewired? Any advice/experience appreciated.
Re: Central Locking Key Remote
Post by Doone » Fri Jul 17, 2009 11:32 pm
I'm probably asking the obvious, but have you tried a new battery?
MintyMat
Post by MintyMat » Fri Jul 17, 2009 11:38 pm
Sorry, should have said, yes - I've replaced the battery. Problem is the same.
jumper
Post by jumper » Fri Jul 17, 2009 11:40 pm
Have you tried that stunt they showed, i think it was on top gear , a few years ago where you get your central locking key and walk away from your car untill it wont operate the locks because its out of range, then put the key against your head, point at the car and it will operate the locks. it actually works :lol: :lol:
Happiness isn't having what you want its wanting what you have.
Post by Doone » Fri Jul 17, 2009 11:41 pm
THIS link may help.
MintyMat
Post by MintyMat » Fri Jul 17, 2009 11:42 pm
Sounds fun, but I will probably only be able to unlock the car as however close I put the remote when locking it rarely locks.
MintyMat
Post by MintyMat » Fri Jul 17, 2009 11:43 pm
Doone wrote:THIS link may help.
Looks useful, but does it explain why unlocking always works and locking rarely?
Post by Doone » Fri Jul 17, 2009 11:50 pm
From reading it, I got the impression that faults can be due to either the remote locking sensor (and it tells you where it is so you can check it yourself) or the key fob.
miker
Post by miker » Sat Jul 18, 2009 12:16 am
:lol: #-o Doone, you can lead a horse to water.......
MintyMat
Post by MintyMat » Sat Jul 18, 2009 7:56 am
Doone wrote:From reading it, I got the impression that faults can be due to either the remote locking sensor (and it tells you where it is so you can check it yourself) or the key fob.
Thanks. I'll have a look inside the driver's door panel and check the wiring. I always thought the little sensor near the windscreen on the driver's side of the dashboard was the door sensor - I wander what that's for?!
Post by missfixit70 » Thu Jul 30, 2009 7:53 pm
daveblueozzie
Post by daveblueozzie » Thu Jul 30, 2009 8:03 pm
Probably not related to any problems in the earlier posts, but been having remote locking problems myself, it will lock the drivers door but not any other, been like this a couple of weeks, i have found the answer but it cost me £80. :shock:
It turned out my leisure battery was duff and not holding a charge, new leisure battery (hence the £80) and all is working as it should. :D
Happy, but a bit short in the wallet now. #-o
Lost without my Bongo.
Post by missfixit70 » Thu Jul 30, 2009 8:07 pm
Good point Dave, that was the first thing that started playing up when I had alternator/LB problems.
Scott
Post by Scott » Thu Jul 30, 2009 8:08 pm
In what year did they start fitting remote central locking into the Bongo's/Freda's, does anyone know ?
The user formerly known as csmcqueen ;)
スコット
daveblueozzie
Post by daveblueozzie » Thu Jul 30, 2009 8:13 pm
csmcqueen wrote:In what year did they start fitting remote central locking into the Bongo's/Freda's, does anyone know ?
mine was an after market central locking with the alarm.
