Help My Roof Wont Rise!
Vicky007
Been camping this weekend and went to raise my auto freetop roof the dashboard light for the roof comes on and goes off like normal but when u press the botton to raise the roof nothing, no sound or movement, could it be a fuse that has blown somewhere? and if so where am i likely to find the fuse any help gratefully received.
thomas104
Re: Help My Roof Wont Rise!
without sounding like a silly did you have the handbrake on and in nuetral !! just something i did not do one time
Vicky007
yeah checked all that first once i new there was a problem.
The AFT fuse is number 12 and is 30Amps its located middle row fourth from left.
- missfixit70
Fuse is no 12, 4th from left on the second row, should be a green 30 amp fuse, if you look in the fusebox factsheet in the members area it shows it.
If you lift the plastic console, there's a switch at at the back of the handbrake, quite often this gets damp, oxidises & doesn't work, give the switch a good scrape on the faces that make contact, chances are that'll solve it. Give me a shout if not Vicky
Beat me to it Geoff
Beat me to it Geoff
I thougth it had to be in 'park' with the handbrake on for the roof to raise.handbrake on and in nuetral
Beyond A to B
- missfixit70
Shouldn't matter what gear it's in as long as the handbrake is on, mine goes up in any gear.dom_e wrote:I thougth it had to be in 'park' with the handbrake on for the roof to raise.handbrake on and in nuetral
Vicky007
Roof is now rising perfectly was down to the hand brake switch thing so panic over thanx guys.
aitch
- Location: in a place far, far away, well Somerset for now!!!
A quick fix - the type we like to hear about well done you
- missfixit70
Seems to sort most of them
Same thing happened to Hotpot when she turned up at the Bash, luckily she was pitching behind me, so it was instantly sorted, just as well as it was nearly 1 am
