Sar N Ade
Post
by Sar N Ade » Wed Aug 19, 2009 2:28 pm
Well I have the water pump now. Eurocarparts were the best price but are rubbish at customer service
so, having waited 24 hours for them to call back in half an hour (as the website had a 'soap' error whatever that means) I got the pump from our local car parts place for £50. It is the QH one.
Mel is booked into the garage next Tuesday. Chappy has worked on Bongos before, one of his mates used to run an import company and he had to sort out all the servicing, checking, and replacing that needed doing.
Thanks everyone for advice - I hope the actual job is straightforward now...
Sarah
not so old
Post
by not so old » Wed Aug 19, 2009 4:37 pm
Sar N Ade wrote:Well I have the water pump now. Eurocarparts were the best price but are rubbish at customer service
Sarah
Hi Sarah, Just seen this thread(been away) I hope all goes well and not too expensive
You really should get an alarm fitted. It's well worth the peace of mind
Neil954
Post
by Neil954 » Wed Aug 19, 2009 5:30 pm
Sarah
Can you let me know how you get on once the work is complete as I'm trying to find a decent/reliable garage in the area.
Neil
Sar N Ade
Post
by Sar N Ade » Wed Aug 19, 2009 8:50 pm
No problem Neil.
We have used this mechanic before - he grew up in the house opposite Adrian and his parents still live there! This is the first 'big' Bongo job though - it has only been MOTs and services before.
I'll keep you informed
Sarah
Post
by missfixit70 » Wed Aug 19, 2009 9:07 pm
Let's hope he's one of the rare one's that's willing to listen to the customer, Make sure he bleeds it PROPERLY, not just how he thinks
Sar N Ade
Post
by Sar N Ade » Wed Aug 19, 2009 9:09 pm
I agree Kirsty!
He says he has done them before and has allowed extra time on his labour quote to do the job.
We'll just have to wait and see I suppose. He has always done an excellent job with our 'ordinary' cars.
Sarah
Sar N Ade
Post
by Sar N Ade » Fri Aug 28, 2009 8:07 pm
Well I am eating my words
Took the van to the in laws tonight (about a mile away) and on the way back the temp shot up (about 200 yards from home) so we stopped. Loud hissing noise and steam.
I'll be phoning the mechanic on Tuesday. Do you think he didn't bleed it right??
("Oh, I've replaced the coolant and bled 3 or 4 of these a week when my mate had his import business....")
Sarah
not so old
Post
by not so old » Fri Aug 28, 2009 8:24 pm
Sar N Ade wrote:Well I am eating my words
Sarah
Oh No! Sarah. How Awful
You poor things
I hope That, it isn't the worse
and can be fixed
Please keep us posted . I will be thinking of you with fingers crossed that it is repairable .
Anna
Post
by missfixit70 » Fri Aug 28, 2009 8:29 pm
Doesn't sound good, what was his reaction to you taking him the printouts of the bleeding procedures, did he read them or do the usual "I know what I'm doing,don't need that crap kind of attitude"?
Did you check the header tank level before you set off? where is the level now? Hopefully it'll just need bleeding properly, let's hope there's not any serious problems been caused, but if you've got an unmodified gauge that's shot up, that's hot.
Hate to say it but Mason & or coolant alarm would have given you warning before it got to that point.
Post
by Doone » Fri Aug 28, 2009 8:39 pm
I'm stating the obvious, but yes, there's something wrong. Did the mechanic follow the factsheet? If not get him to bleed it again. Did he leave it overnight and check the levels the next day? If it was bled right then obviously there's another problem and it depends how hot it got when the water pump seized.
Sar N Ade
Post
by Sar N Ade » Fri Aug 28, 2009 8:39 pm
Adrian checked the coolant before we went out and it was about on max.
He topped it up at his dad's and we took a steady run home as we were concerned by that stage. We were parked on a bend (at the top of a cul de sac so not quite a selfish as it sounds) so we had to move it. When the temp shot up and we stopped Adrian walked to a friend's to see if he had any coolant (he didn't) so we put water in just to get it round the corner off the main road.
Doesn't look good does it.
Anna, we may be coming to Hurley in the Fiesta and sleeping in the awning
Sarah
PS Kirsty, I was pursuaded to not give the printed off sheets to the mechanic as I was being a fussy control freak again and I should just stop meddling. Wish I had meddled now...
Post
by Doone » Fri Aug 28, 2009 8:44 pm
We all live and learn.
With luck it could be something simple, either not bled right, a leak letting air in or stuck thermostat etc. There's a lot to think about.
Sar N Ade
Post
by Sar N Ade » Fri Aug 28, 2009 8:45 pm
Doone, the mechanic had done 'loads' of Bongo coolant issues before and 'knew what to do'. Of course this could be true and this is another problem, not caused by the replacement of the water pump. Mechanic said he ran the engine for hours and told us to check the level before we set off, which we did. It was fine, no coolant loss sat on the drive.
We are both really down now, but it may not be as bad as I think (not the most optimistic type
It's happened to better bongo owners than us!
Sarah
not so old
Post
by not so old » Fri Aug 28, 2009 8:55 pm
Sarah I feel so sad, for you both, but I am a worrier too! and often things aren't as bad as they seem ! It is possibly something that will be easily fixed. I hope you know the answer soon and it is better news than you are expecting. Good Luck and don't upset yourself worrying too much .
Anna & Jimmy( with fingers crossed) X
owelly
Post
by owelly » Sat Aug 29, 2009 7:45 am
Firstly, bleeding the coolant system isn't the bizzarre magical dance as folks would have you believe. It's common sense to any proficient mechanic.
Secondly, what was wrong with the pump? A 'sheared gasket' makes no sense. A leaky gasket does but that would require a new gasket to fix it, not a new water pump. A gasket wouldn't rattle as it fell off even if it could fall off! If the pump had seized and the pulley had sheared, as long as you stopped ASAP and the coolant temperature didn't shoot up, then you shouldn't have overheated the engine.
Thirdly, when the vehicle overheated after the pump fitting, as long as you stopped before the temp left the top of the gauge, then you should be OK. I would top it up with water, open the bleed pipe and let the water run through and then hold the bleed pipe as high as it will go, and overfill the expansion bottle. Leave the cap off and start the engine for 30 seconds or so. Then drop the bleed pipe until the expansion bottle level is correct. Fit the bleed pipe bung and expansion bottle cap. Run the engine for a few minutes then check the level. Go for a run and check again.
Fourthy, do a little dance as your Freda is as good as new. Hopefully.....
