I have recently fitted new stereo.
Yesterday, following a couple of hours of intermitent power, the stereo went down. I assumed it was a loose connection, but having checked over connectors and cables, cannot get it to work.
It could be the stereo itself, but before i consider contacting vendor, what else should i check?
Any advice much appreciated.
No Stereo Power - Any ideas?
doropelu
- missfixit70
Re: No Stereo Power - Any ideas?
Is it working off the leisure battery or the main battery? Could just be the battery supplying it is losing charge? have you checked the fuses? should be number 8 (top right) if stereo hasn't been rewired to the leisure battery.
doropelu
Thanks Kirsty,
Thats the problem - i also fitted a L Battery recently, and its not been charging. My blinds are not working either.
I will investigate this morning, and see how i go!
- missfixit70
Continued on new topic here - http://www.igmaynard.co.uk/bongo/forum/ ... 85#p337885 this will be locked to prevent duplication.
