Hold Light flashing and Speedo not working
				mike2564
Any ideas, got up this morning, Bongo started fine, and was performing ok, the hold light began to flash and the speedo stopped working. I switched it off and re started further down the road.. now all ok... why? Mike
Re: Hold Light flashing and Speedo not working
Have a search on here but I recall it being explained that the autobox takes a signal from the speedo. If the speedo has been 'chipped' to get KPH into MPH and if a connection goes dodgy (or summat like that) then the autobox gets a dodgy signal and the HOLD light registers a fault. Should not be a serious thing to get fixed but have a search for best advisce on what to do.mike2564 wrote:Any ideas, got up this morning, Bongo started fine, and was performing ok, the hold light began to flash and the speedo stopped working. I switched it off and re started further down the road.. now all ok... why? Mike
Good luck - keep us posted.
				bongomaan
i have had this problem and with dandywarhols help traced it to the middle temp sensor in the head,regards neil...
				Matt&JoyBongling
 - Tribal Elder
If you have installed any electrical items connecting to the back of the dash - E.g some alarms, speedo chip, check that the connections are still OK - I had problem with mine which was down to a dodgy connection.  All sorted now.
									Underground, Overground, Bongoling Free, the Bonglers of Bedford, common are we ...
				mike2564
Hey thanks all for your advice, it seems to be behaving itself, but i will know where to look if it fails again. Thanks again Mike Off to Bala For the weekens... yipee!
This happened to me  - dodgy speedo connection. Hard thump on the dash top above the speedo fixed it  - for a while  -  until I got around to (carefully) tightening the connections
									Origo bio stove - no Bongo!
				moonshine
I had this same problem too, and my speedo was fitted with a chip.  It only occurred once in a while, and when it did I just switched the ignition off and re-started the engine.  Cured it every time.  Eventually I fitted a speedo from a Mazda 626 and it never happened again.
same thing happens here from time to time but as said just restart and all is ok so we dont worry about it
						- hembramacho
We're off to Bala this weekend also - may see you around. We're in a white AFT.mike2564 wrote:Hey thanks all for your advice, it seems to be behaving itself, but i will know where to look if it fails again. Thanks again Mike Off to Bala For the weekens... yipee!
Andrew
