Is there an easy way to bleed the fuel system on a diesel Bongo 2.5.
Does anyone know of any way to do it, or what fact sheet to read from members area..
I have searched forum but can find a how to...
Jon
is there an easy way to bleed the fuel system on a diesel
- missfixit70
Re: is there an easy way to bleed the fuel system on a diesel
The factsheets are in the members area, I think 3 different methods are described.
draper3000
yeah sorry did'nt make myself very clear...
I am a member and can access the factsheets....do you know which one refers to bleeding fuel?
- missfixit70
I'd check you've got no leaks & the pick up in the tank isn't blocked as well as the fuel strainer & filter.
- missfixit70
This is runnig in parallel with a very similar thread form the same poster so I'll lock this one to prevent confusion & any further comments should go here - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=34780
