Noisy roof
Barrington
Noisy roof
HELP PLEASE Hi people got a noise problem>>>> when lowering my roof or opening it it makes a horrible groaning noise any one know why many thanks barry.
Music is my Sanctuary!
aitch
- Location: in a place far, far away, well Somerset for now!!!
Re: Noisey roof
Mine is also quite noisy when lowered - I think due to the air being pushed out.
if you put your location in by clicking user control panel top right somebody local to you might be able to help more.
Re: Noisy roof
Try lubricating the runners at the bottom (inside and out), also polish the hydraulic rams.
- mister munkey
Re: Noisy roof
You need a spray can of this Barry
Sqiurt it on the runners & the shiney bits of the hydraulic lifting arms & all the groans will be gone.
Barrington
Re: Noisy roof
Could the groaning be a delayed stored response to dodgy posts like mine, claiming to help, but actually causing the previous posters to wish they hadn't logged in...? & not even a funny picture or nothing. I don't even have an AFT.
Sorry to hear about yer roof Barry... If it's any consolation the sunroof on my tin top sounds like Carol Vorderman on a record turntable when it opens...
Barrington
Re: Noisy roof
How Do i polish the hydrolic rams to keep noise at bay any help would be greatfully appreciated cheers barry?????????
Re: Noisy roof
Got to be careful here. My roof groans too sometimes, but usually going up, and a little lubrication as advised above sorts it. Hopefully the same will work for you. But there can be groans of a different sort altogether, indicating something more serious. Without hearing it, its hard to compare notes (do groans have notes?
). So don't be blinded by our advice - keeps your eyes and ears open and proceed with caution
Re: Noisy roof
I think any suitable lubricant (PTFA, 3 in 1 oil, butter, veg oil, vaseline), maybe put on a clean cloth which is then wrapped gently round the polished bare metal of the rod and then used to smear it, ought to get rid of the noise. If it doesn't, then the problem may be something more serious. As regards what is best to use, I'm not sure but I have some PTFE spray and thats what I use. It needs doing regularly as and when the groan reappears.barry wrote:How Do i polish the hydrolic rams to keep noise at bay any help would be greatfully appreciated cheers barry?????????
- mikexgough
Re: Noisy roof
I cleaned the runners and the rams with a lint free cloth then sprayed with GT85... although TF2 does the same....they are Teflon based Bike sprays similar to WD40....only much better for external use......... pay attention to the small plastic wheels and the runners....quick tip..... have a cloth ready to keep the spray off of the roof tent and to mop up any excess....try the roof then .....I never needed to lubricate my lift arms.....you might not need to either....
Barrington
Re: Noisy roof
Yeah noisy AFT here to
Sparky
Sparky
The Bongo has gone. Long live The Bongo
Hymer Camp Swing 544/Fiat Ducato 2.3jtd
