I hope you've already had a good trawl around the forum, used the search facility as dandywarhol suggests and read lots of other posts, but I will just reiterate what is said many hundreds of times on the forum that the Bongo's temperature gauge is as much use as a chocolate teapot and sits at "11 o'clock" until the Bongo has overheated so catastrophically that damage is likely to have been done.karlos wrote:You get to know the normal running perameters say, town trip, motor way, towing. If the bongo starts operating out side the norm acting it's time to pull over or reduce speed before serious harm is done
Unlike many on this forum whose advice on the technical/mechanical/engineering front has been invaluable to so many of us, I've got the technical knowledge of a soap dish and short of checking levels, tyres etc I leave anything else to a mechanic but you do need to get a Bongo specific alarm fitted. This is a good thread for starters http://www.igmaynard.co.uk/bongo/forum/ ... 08&start=0 but as dandy says, there are lots.
